fields and factors in simpleFunctionObjects
Old   May 17, 2012, 10:29
Default fields and factors in simpleFunctionObjects
BigPapi34 is on a distinguished road
I have a specific question regarding simpleFunctionObjects. Here is an extract from my controlDict file:
p
type patchAverage;
functionObjectLibs
"libsimpleFunctionObjects.so"
verbose true;
patches
outlet
fields (p);
What I would like to know is whether there is a way of multiplying the (p) fields by a factor in order to log a different value and print it to the screen. Is this possible?
On a further note, is there a method of taking the values from the 'outlet' patch above and adding/subtracting the value for the inlet patch (which I have as a different item), printing this to screen and the log file?
Any information would be greatly appreciated.
Thanks
BigPapi34 is offline   Reply With Quote
Old   May 21, 2012, 17:18
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Originally Posted by BigPapi34 View Post
p
type patchAverage;
functionObjectLibs
verbose true;
patches
outlet
fields (p);
Thanks
Multiplication by a factor is supported and even documented: http://openfoamwiki.net/index.php/Co...to_controlDict (but I'm not 100% sure whether patchAverage supports it)
Concerning your second question: not with the pure simpleFunctionObjects but with swak4Foam (of which the simpleFunctionObjects are now a part) which has a function object patchExpression (which builds on simpleFunctionObjects) that allows calculation of expressions on patches. An example for a pressure difference would be:
pressureDiff {
        type patchExpression;
        patches (
            inlet
        variables (
            "pOut{patch'outlet}=sum(p*area())/sum(area());"
        accumulations (
            average
        expression "p-pOut";
        verbose true;
BTW: if patchAverage doesn't allow multiplication with a factor then of course patchExpression might be the solution too
gschaider is offline   Reply With Quote
