How long does it take to do implementation of new schemes? |
July 7, 2020, 09:14 |
Březňák
Rep Power: 5 |
I try to do implementation of the two schemes, LDDRK (Low-Dissipation and Low-Dispersion Runge–Kutta Schemes) and DRP (Dispersion-Relation-Preserving Schemes). I already have the two original papers, and I would like to start to work if it takes about 2-3 months... I never tried implementation, just have used OpenFOAM only for simulations. |
July 7, 2020, 14:14 |
Ardalan
Rep Power: 13 |
This is entertaining questions. It really depends on your skills and hard working. If you work full time on an implementation you will be able to debug it in 2-3 months. Hint: many schemes or schemes very similar to what you want are already implemented in OpenFoam. google things before start working on a code. good luck Ardalan |
July 8, 2020, 13:05 |
#3 | |
Březňák
Rep Power: 5 |
Maybe they also implemented the schemes themselves? |
July 8, 2020, 14:07 |
Ardalan
Rep Power: 13 |
Yes, I meant unofficial implementation. implementation of schemes in OpenFoam is not new issue.
Implementation of High Resolution Schemes in Fluent-Ansys | Pmaroul | FLUENT | 0 | October 24, 2018 13:30 |
implementation of schemes in openfoam | venkataramana | OpenFOAM | 24 | February 21, 2018 11:09 |
correct finite volume schemes | babakflame | OpenFOAM Running, Solving & CFD | 2 | July 7, 2017 16:55 |
Better organization of Convective Term approximation schemes | Michail | CFD-Wiki | 0 | March 15, 2012 12:56 |
Higher-order bounded convection schemes for pure advection with discontinuity | Anthony | Main CFD Forum | 3 | June 13, 1999 02:36 |
