November 28, 2012, 21:46 |
Two ODE objects simultaneously
James Behzadi
Dear all,
I have a rather non-conventional problem to solve. It is a PDE which people split it into stiff and nonstiff ODE's. The result of this "operator splitting" is two different sets of ODE's which can be solved separately. The problem is that the number of equations are not the same. Let's say I have n1_ nonstiff ODE's and n2_ stiff ODE's. My understanding of existing architecture of OpenFOAM 2.0.x is that, it allows the use of only one ODE solver at a time. The ODE object is constructed at runtime, and all the variables used in the integration are initialised at the constructor of the ODESolver class, viz. Code:
Foam::ODESolver::ODESolver(const ODE& ode) : n_(ode.nEqns()), yScale_(n_), dydx_(n_) {} I searched the forum in hope of finding something relevant. I cam up with the following threads, but apparently none of them address my problem. A trial of implementing of CVODE as ODESolver Problem implementing CVODE ODE solver (see post #15) OpenFOAM 1.7 and CVODE My questions: 1) Is there any way to create two ode objects that one of them uses one ODEsolver (SIBS per say) and the other one uses another (RK for example)?! 2) Or rephrasing my first question, is there any way to use the same ODE solver (SIBS for example) to solve two different sets of ODE's with n1_ and n2_ equations?! Jalal |
cvode, operator splitting, rk ode solver, sibs ode solver, stiff non-stiff ode |
Using ODE in OpenFoam | skabilan | OpenFOAM Programming & Development | 22 | April 6, 2022 06:05 |
Is it possible to accelerate the ode solver of reactingFoam? | pajofego | OpenFOAM Running, Solving & CFD | 2 | August 10, 2014 05:38 |
IcePak network objects in parallel solver | Alexey | FLUENT | 1 | December 25, 2013 08:32 |
reactingFoam: ODE Solver KRR4 "Too many integration steps" | pajofego | OpenFOAM | 3 | May 18, 2013 15:15 |
Warning when I add my objects | Xu | Phoenics | 0 | November 21, 2008 12:30 |
