Trouble adding a directional derivative source term
Old   March 17, 2013, 20:19
Default Trouble adding a directional derivative source term
Chris Prohoda
cpro is on a distinguished road
Hi everyone. Thanks for checking this.
I am a new OpenFOAM user, and I have been trying to create my own solver to model ferrofluid motion. In the model that I am using, there is a directional derivative source term (i.e. M \cdot \nabla B which I plan to approximate as \nabla\left( M \cdot B \right) where M and B are vectors).
I have M and B set up as volVectorFields, and I want multiply the entire thing by a the volume of each cell over the (constant) density. It looks like the fvc::div function needs one surface scalar field, so I created a phiB in a similar way to the phi for velocity using
(fvc::interpolate(B) & mesh.Sf())
Next, I try to modify phiB by the constant. Here is some relevant code:
            phiB=phiB*mesh.V()/rho;
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
              - fvm::laplacian(nu, U)
            solve(UEqn == -fvc::grad(p) + fvc::div(phiB, M));
When I try to compile it, it lists a large number of errors that were not there before attempting to multiply by volume. So, I think the problem occurs when I multiply by the volume of each cell (using mesh.V), but I'm lost as to how to fix it. Any tips or suggestions? Is there a better way to do this?
I really appreciate your help.
cpro is offline   Reply With Quote
Old   March 19, 2013, 16:51
yijin Mao
alundilong is on a distinguished road
            fvVectorMatrix UEqn
                fvm::ddt(U)
              + fvm::div(phi, U)
phiB ---> surfaceScalarField
mesh.V() ---> volScalarField
rho ---> volScalarField
I think you have to do linear interpolation for volScalarField before math operations.
alundilong is offline   Reply With Quote
directional derivative, ferrofluid, mesh
derivative of source term denise Fluent UDF and Scheme Programming 1 October 29, 2009 04:41
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
UDF Source Term Units? Brian FLUENT 1 October 24, 2005 09:15
Directional Diffusivity of UDS Source Greg Perkins FLUENT 2 September 4, 2003 03:02
