A solver for two-phase flow with a porous media |
June 23, 2013, 01:54 |
Jeong Kim
Rep Power: 16 |
Dear formers,
I'm looking for a OF solver for two-phase flow with a porous media. There is a porous region in the middle of a channel where air can go through the porous media, but liquid cannot. I'd like to consider each momentum equation for each component. So I'm looking for a solver consisting of twoPhaseEulerFoam and porous media. I'd really appreciate that if you could give me some guidelines. Thanks in advance for your comments. |
July 13, 2020, 12:38 |
Armin Alavi
Rep Power: 6 |
Hello Jeong,
Did you manage to solve your problem? I am kind of struggling with a similar one. I am using explicit porousity via fvOptions for compressibleInterFoam solver, i want my gas phase to diffuse through the porous medium freely but I don't want my liquid phase to diffuse. Do you have any suggestions on that? Any guidance is greatly appreciated. Thank you Armin |
July 13, 2020, 13:32 |
#3 | |
Rohit George Sebastian
Rep Power: 9 |
I am not sure if I understood your problem correctly. I only have experience using explicitPorositySource with interFoam, but wouldn't one phase fill the volume not filled by the other? So in your case, any cell that is not filled with the liquid phase should be filled by the gaseous phase. |
July 13, 2020, 14:14 |
Armin Alavi
Rep Power: 6 |
Hello
Thanks for your reply. In my simulation, I have a two phase (liquid-gas) flow surrounded by a porous medium. My problem is that my liquid phase starts to penetrate through the porous medium which should not! I am looking for a way to stop that. |
August 5, 2020, 09:23 |
Armin Alavi
Rep Power: 6 |
Hello again
Can anyone help me with this problem? I tried various things, they all failed. I would appreciate any help |
September 27, 2022, 04:09 |
#6 | |
Thanks and regards |
October 10, 2022, 09:11 |
Raphael Santos
Rep Power: 12 |
check OF10, version. There is a tutorial named bed, which simulates multiphaseEulerFoam using solid as a phase. It is not a porosity term, but a way to simulate a flow in porous media. regards, |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 04:09 |
Modeling unsteady multiphase flow in porous media - convergence problem | Vaibhav Kumar | Main CFD Forum | 1 | July 22, 2012 04:32 |
Problem of mass conservation in multispecies flow in porous media and T° gradient | pilou | FLUENT | 0 | January 31, 2011 08:19 |
Compressible flow through porous media? | JoFFe | CFX | 2 | November 1, 2010 04:50 |
rotating porous media in a general flow | a_dores | FLUENT | 0 | October 31, 2010 04:50 |
