control reaches end of non-void function
Old   June 25, 2013, 20:28
Default control reaches end of non-void function
Dongyue Li
sharonyue is on a distinguished road
I want to modify the "muf" and "nuf"'s function in twoPhaseMixture.C. The function is this:
"muf",
            rho2_*fvc::interpolate(nuModel2_->nu())
            + (rho1_*fvc::interpolate(nuModel1_->nu())
               rho2_*fvc::interpolate(nuModel2_->nu()))
            *(exp(128*alpha1f)-1)
            /exp(2)
When I wmake libso, it said:
cfd@cfd:~/myCase/mylib/incompressibleTwoPhaseMixture/incompressible$ wmake libso
Making dependency list for source file incompressibleTwoPhaseMixture/twoPhaseMixture.C
SOURCE=incompressibleTwoPhaseMixture/twoPhaseMixture.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I.. -I/opt/openfoam220/src/finiteVolume/lnInclude -IlnInclude -I. -I/opt/openfoam220/src/OpenFOAM/lnInclude -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/twoPhaseMixture.o
incompressibleTwoPhaseMixture/twoPhaseMixture.C: In member function ‘Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam::twoPhaseMixture::muf() const’:
incompressibleTwoPhaseMixture/twoPhaseMixture.C:160:19: error: call of overloaded ‘exp(int)’ is ambiguous
incompressibleTwoPhaseMixture/twoPhaseMixture.C:160:19: note: candidates are:
In file included from /opt/openfoam220/src/OpenFOAM/lnInclude/floatScalar.H:78:0,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/scalar.H:39,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/IOstream.H:49,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/Ostream.H:39,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/UILListIO.C:27,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/UILList.C:92,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/UILList.H:285,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/ILList.H:39,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/IDLList.H:35,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/entry.H:45,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/dictionary.H:53,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/IOdictionary.H:42,
                 from incompressibleTwoPhaseMixture/transportModel.H:39,
                 from incompressibleTwoPhaseMixture/twoPhaseMixture.H:38,
                 from incompressibleTwoPhaseMixture/twoPhaseMixture.C:26:
/opt/openfoam220/src/OpenFOAM/lnInclude/Scalar.H:260:1: note: Foam::floatScalar Foam::exp(Foam::floatScalar)
In file included from /opt/openfoam220/src/OpenFOAM/lnInclude/doubleScalar.H:78:0,
                 from /opt/openfoam220/src/OpenFOAM/lnInclude/scalar.H:40,
/opt/openfoam220/src/OpenFOAM/lnInclude/Scalar.H:260:1: note: Foam::doubleScalar Foam::exp(Foam::doubleScalar)
In file included from incompressibleTwoPhaseMixture/viscosityModel.H:55:0,
                 from incompressibleTwoPhaseMixture/twoPhaseMixture.H:39,
/opt/openfoam220/src/OpenFOAM/lnInclude/dimensionedScalar.H:73:19: note: Foam::dimensionedScalar Foam::exp(const dimensionedScalar&)
incompressibleTwoPhaseMixture/twoPhaseMixture.C:163:1: warning: control reaches end of non-void function [-Wreturn-type]
make: *** [Make/linux64GccDPOpt/twoPhaseMixture.o] Error 1
If I delete the last exp(2), it succeed, does anyone know why? Thanks in advance.
BTW,if I want to over exp(128), how to make it?
sharonyue is offline   Reply With Quote
Old   June 26, 2013, 10:36
David Gaden
marupio is on a distinguished road
exp() is defined for all types, and you are giving it a literal constant. The compiler can't tell which exp() function to call. Try giving it more scope:
scalar::exp(2.0)
or
exp(scalar(2.0))
Share and enjoy!
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   June 26, 2013, 19:54
Dongyue Li
scalar::exp(2.0)
or
exp(scalar(2.0))
Share and enjoy!
That's cool! exp(scalar(2.0)) works, thanks!!
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Radiation interface hinca CFX 15 January 26, 2014 17:11
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 15:34
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
