how to share a scalar between processors in parallel Run |
July 19, 2013, 05:27 |
Hi all
I want to solve the single DOF forced and damped vibration equation for displacement of tip point of a plate(m*d2x/dt2+c*dx/dt+k*x=F) and displacement of other points of plate are explicitly obtained from the first mode of the plate the code in serial run give correct results when I run this code in parallel for calculating displacement of other points of plate only the first processor is used correct x and others processors is used zero instead of x how can I share the x value between all processors ? |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 07:15 |
dieselFoam problem!! trying to introduce a new heat transfer model | vivek070176 | OpenFOAM Programming & Development | 10 | December 23, 2014 23:48 |
Parallel run - number of processors | danvica | OpenFOAM Running, Solving & CFD | 4 | April 5, 2012 11:57 |
Can't run in parallel | JulytoNovember | OpenFOAM Running, Solving & CFD | 2 | March 31, 2012 09:28 |
SnappyHexMesh OF-1.6-ext crashes on a parallel run | norman1981 | OpenFOAM Bugs | 5 | December 7, 2011 12:48 |
