LES compressible turbulence model
Old   September 6, 2013, 13:19
Default LES compressible turbulence model
Bojan Sekutkovski
Bojan is on a distinguished road
Hi everybody,
I just have succeeded to compile modified turbulence model for compressible LES, and after running solver (any solver), I get an error message as follows:
rhoCentralFoam: symbol lookup error: /opt/OpenFOAM-2.2.0/platforms/linux64GccDPOpt/lib/libcompressibleLESModels.so: undefined symbol: _ZNK4Foam12compressible9LESModels12kOmegaSSTSAS10d evRhoBeffEv
Is there any idea how to overcome that?
Regards!
Bojan is offline   Reply With Quote
Old   September 7, 2013, 04:37
Default Solution
Bojan Sekutkovski
In the meantime I've found the soilution of the problem with "undefined symbol". Every virtual function that is declared in the class must be defined in the source file.
Regards!
compressible les, komegasstsas, les
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 09:52
y+ for LES turbulence model Pawan FLUENT 0 December 7, 2007 00:40
Problem with LaunderSharma compressible turbulence model wrong formulation luca OpenFOAM Running, Solving & CFD 4 July 3, 2006 06:24
give me some advice about compressible LES. Bin Li Main CFD Forum 3 September 19, 2003 13:01
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
