strainrate()
Old   September 23, 2013, 04:18
Default strainrate()
Dongyue Li
sharonyue is on a distinguished road
Hi guys,
This is a piece of code in viscosity.C
Foam::tmp<Foam::volScalarField> Foam::viscosityModel::strainRate() const
    return sqrt(2.0)*mag(symm(fvc::grad(U_)));
Mathematically, it is\gamma  = \sqrt 2  \cdot \left| {\frac{1}{2}\left( {\nabla u + \nabla {u^T}} \right)} \right|
but how can I get the magnitude of a tensor? and why isn't this strainrate a tensor but a scalar? Shouldnt it be:
Foam::tmp<Foam::volTensorField> Foam::viscosityModel::strainRate() const
    return symm(fvc::grad(U_));
sharonyue is offline   Reply With Quote
Old   September 24, 2013, 03:27
Albrecht vBoetticher
vonboett is on a distinguished road
mag(D) = sqrt(D_ij D_ij ) = norm of strain rate tensor in OpenFOAM, where D_ij = 1/2 ((grad(U)+grad(U)^T) = symm(grad(U)) = 2*DR and that is a scalar. There are several definitions of the norm, this is one wideley used to calculate a kind of "magnitude" of the tensors components
vonboett is offline   Reply With Quote
Old   September 26, 2013, 03:41
Dongyue Li
Sorry. Are you sure this is a scalar?
Old   September 30, 2013, 09:35
Sorry, more precise: norm(D) = sqrt{trace(D^2)}, so if I am correct Dij above would be: Dij = 0.5*(du_i/dx_j + du_j/dx_i) + 0.5(du_i/dx_j - du_j/dx_i).
Please check if I messed with the indices, du_/dx_ stands for the corresponding derivative of the velocity.
StrainRate definition 141 vs 15 floooo OpenFOAM Running, Solving & CFD 19 June 27, 2017 13:36
Plotting strainRate Studi OpenFOAM Programming & Development 10 July 22, 2015 20:24
