July 16, 2013, 14:08 |
Issues running custom code in parallel
Scott Ripplinger
Rep Power: 13 |
I am working on a solver that I've developed using the solidParticle class as a base. I've gotten the code to run properly in serial, but when I try running it in parallel it gets stuck. I've narrowed it down to where a interpolationCellPoint<vector> is declared. While I have modified the code some, this would analogous to line 79 of solidParticleCloud.C (I have lines 78 and 80 commented out). Any ideas of why the code would get stuck here when running in parallel?
Problem running OpenFOAM 2.2.x in parallel in Centos 5 | lvalvare | OpenFOAM Running, Solving & CFD | 33 | December 9, 2020 08:44 |
Case running in serial, but Parallel run gives error | atmcfd | OpenFOAM Running, Solving & CFD | 18 | March 26, 2016 12:40 |
Problem in Running OpenFoam in Parallel | himanshu28 | OpenFOAM Running, Solving & CFD | 1 | July 11, 2013 09:19 |
How to make code run in parallel? | cwang5 | OpenFOAM Programming & Development | 1 | May 30, 2011 04:47 |
Adding Custom Tab in FLUENT using Scheme Code | dhimans | Fluent UDF and Scheme Programming | 0 | September 14, 2009 15:10 |
