how to implement Cmu changing with mesh coordinates
Old   December 3, 2013, 05:21
Default how to implement Cmu changing with mesh coordinates
zdong
abbott.hn is on a distinguished road
I need to make the constant Cmu in kEpsilon turbulence model in OpenFOAM-2.2.1 to change with height like this :
Cmu=pow(uStar,4)/(D1*ln(z+z0)+D2)
in which uStar D1 D2 z0 are predefined constants,and z is the z-coordinate of the mesh. I have tried it like this in the *.C file of myKEpsilon model:
Cmu_
           IOobject
                     "Cmu",
                     runTime_timeName(),
                     mesh_,
                     IOobject::MUST_READ,
                     IOobject::AUTO_WRITHE
           mesh_
and in the *.H file i declared Cmu_ as the volScalarField.
My problem are :
1) From certain reference paper, the ignoring of the BC typeName in the parameters list of IOobject means the Boundary condition of the defined geometricField will be then calculated, so am I ritht to define the Cmu field like this or there is a better solution or even the Cmu could not defined as volScalarField at all?
2) If the above definition for Cmu field is appropriate, then how can i initialize the Cmu nonuniformly in the 0/Cmu file, as it's associated with the mesh coordinates, and for what the boundary conditions should applied , the Dirichlet BC ?
Thanks for your reply , and the attached file is the source and head files of myKEpsilon.
best regards .
Dong
abbott.hn is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 08:52
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
