method Foam::tmp<Foam::fv::gradScheme<Type> > Foam::fv::gradScheme<Type>::New |
December 22, 2013, 06:37 |
Rep Power: 14 |
hi I have a question about the following method:
SNIPPET1 template<class Type> 33*Foam::tmp<Foam::fv::gradScheme<Type> > Foam::fv::gradScheme<Type>::New //Return a pointer to a new*gradScheme*created on freestore. 34*( 35* const fvMesh& mesh, 36* Istream& schemeData 37*) 38*{ 39* if (fv::debug) 40* { 41* Info<< "gradScheme<Type>::New" 42* "(const fvMesh& mesh, Istream& schemeData) : " 43* "constructing gradScheme<Type>" 44* << endl; 45* } 46* 47* if (schemeData.eof()) 48* { 49* FatalIOErrorIn 50* ( 51* "gradScheme<Type>::New" 52* "(const fvMesh& mesh, Istream& schemeData)", 53* schemeData 54* ) << "Grad scheme not specified" << endl << endl 55* << "Valid grad schemes are :" << endl 56* << IstreamConstructorTablePtr_->sortedToc() 57* << exit(FatalIOError); 58* } 59* 60* const word schemeName(schemeData); 61* 62* typename IstreamConstructorTable::iterator cstrIter = 63* IstreamConstructorTablePtr_->find(schemeName); 64* 65* if (cstrIter == IstreamConstructorTablePtr_->end()) 66* { 67* FatalIOErrorIn 68* ( 69* "gradScheme<Type>::New" 70* "(const fvMesh& mesh, Istream& schemeData)", 71* schemeData 72* ) << "Unknown grad scheme " << schemeName << nl << nl 73* << "Valid grad schemes are :" << endl 74* << IstreamConstructorTablePtr_->sortedToc() 75* << exit(FatalIOError); 76* } 77* 78* return cstrIter()(mesh, schemeData); // typename IstreamConstructorTable::iterator cstrIter (siehe oben) 79*} Code:
//SNIPPET2 template<class T, class Key, class Hash> 145 inline T& Foam::HashTable<T, Key, Hash>::operator()(const Key& key) 146 { 147 iterator iter = this->find(key); 148 149 if (iter == this->end()) 150 { 151 this->insert(key, T()); 152 return *find(key); 153 } 154 else 155 { 156 return *iter; 157 } 158 } greetings maybee |
December 22, 2013, 17:15 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hi Maybee,
You will find the "New" functionality in everthing runtime selectionable function. What it basically does is to construct a specific class; in your case a specific gradient scheme. The information in the parenteses is merely the objects needed to construct that specific gradient scheme. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
On the alpha Eqn of VOF method when using Immersed boundary method in OpenFOAM | keepfit | OpenFOAM | 4 | January 31, 2014 14:32 |
multiphaseEulerFoam: method mag(...) withing method solveAlphase() | maybee | OpenFOAM Programming & Development | 0 | December 21, 2013 10:13 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Comparison: Finite Volume Method vs. Analytic Method | m-fry | Main CFD Forum | 1 | April 20, 2010 14:40 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
