dynamic mesh with solution depended
Old   February 27, 2014, 07:41
Default dynamic mesh with solution depended
Detian Liu
Detian Liu is on a distinguished road
Dear All,
Recently, I am trying to accomplish a case. In the case, I can get the variation (delta y) for every mesh in the bottom boundary for every time step, and I want to generate a new bottom boundary by adding the variation to the old bottom boundary. But I do not know how to read the variation when adapt "dynamicFvMesh". Am I right to adapt the class "dynamicInkJetFvMesh"? Is there anybody who can give me some advice about the dynamic mesh with solution depended?
I just want to read the result in the runtime dictionary, and the .C file is like this:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     |
    \\  /    A nd           | Copyright (C) 2011 OpenFOAM Foundation
     \\/     M anipulation  |
License
    This file is part of OpenFOAM.
    OpenFOAM is free software: you can redistribute it and/or modify it
    under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    OpenFOAM is distributed in the hope that it will be useful, but WITHOUT
    ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
    FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License
    for more details.
    You should have received a copy of the GNU General Public License
    along with OpenFOAM.  If not, see <http://www.gnu.org/licenses/>.
#include "dynamicAddFvMesh.H"
#include "addToRunTimeSelectionTable.H"
#include "volFields.H"
#include "mathematicalConstants.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
    defineTypeNameAndDebug(dynamicAddFvMesh, 0);
    addToRunTimeSelectionTable(dynamicFvMesh, dynamicAddFvMesh, IOobject);
// * * * * * * * * * * * * * * * * Constructors  * * * * * * * * * * * * * * //
Foam::dynamicAddFvMesh::dynamicAddFvMesh(const IOobject& io)
    dynamicFvMesh(io),   stationaryPoints_
        IOobject
            "points",
            io.time().constant(),
            meshSubDir,
            *this,
            IOobject::MUST_READ,
            IOobject::NO_WRITE
    Eta_
        IOobject
            "Eta",
            io.time().timeName(),
            mesh,
            IOobject::NO_WRITE
    mesh
    Info<< "Performing a dynamic mesh calculation: " << endl
        << "amplitude: " << amplitude_
        << " you are win! " << frequency_
        << " refPlaneX: " << refPlaneX_ << endl;
// * * * * * * * * * * * * * * * * Destructor  * * * * * * * * * * * * * * * //
Foam::dynamicAddFvMesh::~dynamicAddFvMesh()
// * * * * * * * * * * * * * * * Member Functions  * * * * * * * * * * * * * //
bool Foam::dynamicAddFvMesh::update()
    Info<< "Mesh scaling. Time = " << time().value() << endl;
    pointField newPoints = stationaryPoints_;
    newPoints.replace
        vector::Y,
        stationaryPoints_.component(vector::Y)
    fvMesh::movePoints(newPoints);
    volVectorField& U =
        const_cast<volVectorField&>(lookupObject<volVectorField>("U"));
    U.correctBoundaryConditions();
    return true;
and it give the error like this:
Making dependency list for source file dynamicAddFvMesh.C
SOURCE=dynamicAddFvMesh.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra  -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3   -DNoRepository -ftemplate-depth-100  -I/opt/openfoam220/src/triSurface/lnInclude  -I/opt/openfoam220/src/meshTools/lnInclude  -I/opt/openfoam220/src/dynamicMesh/lnInclude  -I/opt/openfoam220/src/finiteVolume/lnInclude  -I/opt/openfoam220/src/dynamicFvMesh/lnInclude -IlnInclude -I.  -I/opt/openfoam220/src/OpenFOAM/lnInclude  -I/opt/openfoam220/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o  Make/linux64GccDPOpt/dynamicAddFvMesh.o
dynamicAddFvMesh.C: In constructor ‘Foam::dynamicAddFvMesh::dynamicAddFvMesh(const Foam::IOobject&)’:
dynamicAddFvMesh.C:83:13: error: ‘mesh’ was not declared in this scope
make: *** [Make/linux64GccDPOpt/dynamicAddFvMesh.o] Error 1
could someone give me some advice?
Thank you very much!
Best wishes!
Sincerely,
Detian
2012.2.26
Detian Liu is offline   Reply With Quote
dynamic mesh for drop interface IndrajitW FLUENT 0 March 30, 2013 08:03
dynamic mesh refinement and rhoCentralFoam ChrisA OpenFOAM Running, Solving & CFD 1 March 21, 2013 08:00
Solution Diverging with Trimmer Mesh rietuk STAR-CCM+ 8 February 27, 2013 04:50
I find the solution of mesh dynamic cheredha Fluent UDF and Scheme Programming 0 June 8, 2010 20:24
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
