A library compiling error after upgrading from OpenFOAM 2.2.0 to 2.2.2
Old   May 12, 2014, 18:55
Default A library compiling error after upgrading from OpenFOAM 2.2.0 to 2.2.2
Yijiu Jiang
y_jiang is on a distinguished road
Hi Bruno,
I got some new problems in the recent days. I have my OF-2.2.0 on my cluster. Now I need compile 2.2.2 in the same account. I have already compiled the source code and ThirdParty. But when I try to compile some my own libraries I got a error which shows:
make:*** No rule to make target '/home/jaq526/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc45/openmpi-1.6.3/include/mpi.h, needed by 'xxx.dep'. Stop
So, I think there should be something wrong with the environmental variables.
What I did is as follow:
1. cd $WM_MPLIB
it gives me this:
bash: cd:SYSTEMOPENMPI: No such file or directory
2. which mpirun
it gives me like:
/usr/lib64/openmpi/bin/mpirun which is the system mpi
And I also find I cannot use mpirun command to run my case in the older version 2.2.0 too. So I go back to check the bashrc file and redo the source $HOME/.../ step.
But it give me this message:
Cannot open configuration file /home/jaq526/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc45/openmpi-1.6.3/share/openmpi/mpicc-wrapper-data.txt
I really feel confused by this problem...
Do you have any suggestion on this?
y_jiang is offline   Reply With Quote
Old   May 14, 2014, 04:00
Yijiu Jiang
I just installed of-2.2.2 on my Linux cluster.
I have some libraries to be compiled. But I got the following error message when I compiled one of them. The message is :
make:*** No rule to make target '/home/jaq526/OpenFOAM/ThirdParty-2.2.0/platforms/linux64Gcc45/openmpi-1.6.3/include/mpi.h', need by 'xxxx.dep' Stop.
I think there should be something wrong with the environmental variables, cause
In the /Make/options file, these two lines are included.
sinclude $(GENERAL_RULES)/mplib$(WM_MPLIB)
sinclude $(RULES)/mplib$(WM_MPLIB)
but the weird thing is why the message give me ThirdParty-2.2.0, actually I don't have ThirdParty-2.2.0 now. Does anyone have idea on this?
Old   May 15, 2014, 15:34
Retired Super Moderator
Bruno Santos
Greetings y_jiang,
There are 2 possible problems:
  1. The shell environment variables haven't been updated properly to the new version 2.2.2. Check the contents of the file "~/.bashrc" to see if there are still old references to 2.2.0. Either way, start a new terminal to make sure the environment is clean. For more information of what I'm talking about: http://openfoamwiki.net/index.php/In...with_the_Shell
  2. You probably did not perform a clean up of the previous build. For example, if you use:
    wmake all
    to build your library, then you should first do:
    wclean all
Best regards,
Bruno
Old   May 15, 2014, 22:43
Yijiu Jiang
Yes Bruno, you are right. Thank you. Cause the environmental variables are not update when I copy from the earlier version. I did wclean the old files in Make and seems the problems fixed.
But the paraview gives me a new trouble today. When I type paraFoam, there a new error which is
error while loading shared libraries:libQtWebKit.so.4
:cannot open shared object file: No such file or directory
Old   May 16, 2014, 01:29
Yijiu Jiang
I recompiled cmake and qt. Now ParaView runs with no problem. Thank you Bruno.
Density_based turbo with OpenFoam 2.2.0 eddykendo OpenFOAM 4 March 2, 2014 06:05
ESI-OpenCFD Releases OpenFOAM v2.2.0 opencfd OpenFOAM Announcements from ESI-OpenCFD 13 March 30, 2013 16:52
OpenFOAM Training in Europe and USA hjasak OpenFOAM 0 August 8, 2008 05:33
Can OpenFoam be made faster or which Math kernel library is used jens_klostermann OpenFOAM 0 February 4, 2008 08:37
OpenFOAM Debian packaging current status problems and TODOs oseen OpenFOAM Installation 9 August 26, 2007 13:50
