How to specify number of parcels to be added to cellZone in cellZoneInjection Model |
February 13, 2017, 10:37 |
vidyadhar
Rep Power: 9 |
Hello All,
I am trying for cellZoneInjection to inject particles in my case. The cellZoneInjection.H file specifies the following: Class CML::CellZoneInjection Description Injection positions specified by a particle number density within a cell set - User specifies - Number density of particles in cell set (effective) - Total mass to inject - Initial parcel velocity - Parcel diameters obtained by PDF model - All parcels introduced at SOI Accordingly, I have created injection model (in bubbleCloudProperties File) which looks like below: injectionModels { model1 { type cellZoneInjection; SOI 0.0; massTotal 3.4746e-08; parcelBasisType mass; //fixed; nParticle 1; cellZone particle_INLET1; //particleSupplyCellZone; numberDensity 20000; duration 5e-5; U0 (0 0 0.04175); //(0 0 0); sizeDistribution { type fixedValue; fixedValueDistribution { value 0.48e-03; //0.006; } } } } When I execute my solver, I am getting the following warning message: From function CML::CellZoneInjection<CloudType>::updateMesh() in file lagrangian/intermediate/lnInclude/CellZoneInjection.hpp at line 397 Number of particles to be added to cellZone particle_INLET1 is zero My Simulation is not stopping but, particles are not adding into the domain. Can anyone tell me how to resolve this issue. Thanks & Regards, vidyadhar |
June 9, 2017, 19:41 |
dj
Hello Vidyadhar,
I was facing the same problem when creating a cellZone with topoSet. The cellZone is written to polyMesh/sets/'yourCellZone'. I just copied the CellLabels from that into the file polyMesh/cellZones. Laborious, but worked. Best David |
June 11, 2017, 02:19 |
vidyadhar
Rep Power: 9 |
Hello David,
Thank you for your reply. I got to do in a different way. Thanks to Darrin Stephens for this. injectionModels { model1 { type cellZoneInjection; cellZone INLET; // Name of cellZone SOI 5; // Start Of Injection //flowRateProfile constant 1; // Flow rate profile relative to SOI parcelBasisType fixed; // How are the number of particles calculated nParticle 1; numberDensity 13e05; // numberDensity multiplied by cellZoneVolume gives the number of particles to be injected duration 5e-5; //cellZoneInjection through this manner is a one time injection, i.e., all the particles will be injected at once U0 (0 0 0); //initial velocity of the particles upon injection massTotal 24e-3; // Total mass injected over injection duration sizeDistribution { type fixedValue; fixedValueDistribution { value 1e-03; } } } } Regards, vidyadhar |
October 26, 2020, 08:19 |
UOCFD
Rep Power: 5 |
Hi, I am using cellZoneInjection.
Let's suppose I want to introduce 0.005 kg (massTotal) distributed inside a cellZone defined with topoSet. The number of particles is easy to calculate, since we now total mass and particle volume and density. The volume of this cellZone is known so I calculate the numberDensity as total number of particles/volume of cellZone. However, seems that my computer cannot handle so big number of particles, so how can I include more than one particle in one parcel while keeping total mass equal to 0.005kg. totalMass is totally bypassed when parcelBasisType is fixed. Is nParticle the number of particles in a parcel? Thanks |
[General] Extracting ParaView Data into Python Arrays | Jeffzda | ParaView | 30 | November 6, 2023 21:00 |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 09:23 |
[Other] Can't Shake Erros: patch type 'patch' not constraint type 'empty' | BrendaEM | OpenFOAM Meshing & Mesh Conversion | 12 | April 3, 2022 18:32 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
