Question About Arrhenius viscosity
Old   July 23, 2014, 09:02
Default Question About Arrhenius viscosity
Janaína de Andrade Silva
nainasjdr is on a distinguished road
I'm trying implment Arrhenius viscosity.
Foam::tmp<Foam::volScalarField>
Foam::viscosityModels::ArrheniusDin::calcNu() const
const volScalarField& T= U_.mesh().lookupObject<volScalarField>("T");
return
nu0_* exp(E_/T);
But when I sove my problem this messagem appear
| \\ / O peration | Version: 2.2.2 |
| \\/ M anipulation | |
Build : 2.2.2-9240f8b967db
Exec : TemppimpleFoam
Date : Jul 23 2014
Time : 09:55:19
Host : "cp-jana"
PID : 6073
Case : /home/jana/OpenFOAM/jana-2.2.2/run/Simulacao_Temperatura/temp/Vaso50micro
nProcs : 1
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Reading field T
Selecting incompressible transport model ArrheniusDin
--> FOAM FATAL ERROR:
Argument of trancendental function not dimensionless
From function trans(const dimensionSet&)
in file dimensionSet/dimensionSet.C at line 424.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::trans(Foam::dimensionSet const&) at ??:?
#3 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::exp<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#4 Foam::viscosityModels::ArrheniusDin::calcNu() const at ??:?
#5 Foam::viscosityModels::ArrheniusDin::ArrheniusDin( Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#6 Foam::viscosityModel::adddictionaryConstructorToTa ble<Foam::viscosityModels::ArrheniusDin>::New(Foam ::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#7 Foam::viscosityModel::New(Foam::word const&, Foam::dictionary const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
#8 Foam::singlePhaseTransportModel::singlePhaseTransp ortModel(Foam::GeometricField<Foam::Vector<double> , Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) at ??:?
at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11
at ??:?
Someone Can I help me?
nainasjdr is offline   Reply With Quote
Old   July 23, 2014, 23:04
Cyp
Cyprien
Cyp is on a distinguished road
Hi!
It seems that your variable E_ is not declared are either a dimensionedScalar or a volScalarField. So you tried to compute the exponential of a variable that has the dimension of the inverse of the temperature. Which is no sense since the exponential is dimensionless...
By the way, I also suggest you to use Foam::exp() instead of exp() in order to specify the compiler that you are going to use the overloaded exp function.
Cheers,
Cyp
Cyp is offline   Reply With Quote
Old   July 27, 2014, 18:24
Originally Posted by Cyp View Post
Hi!
Cheers,
Cyp
E_ is a dimensionedScalar...
Old   July 28, 2014, 00:21
Cyp
Cyprien
have you tried with Foam::exp() instead of exp() ?
Old   July 28, 2014, 10:20
Yes. I tried it. But not worked
return
nu0_* Foam::exp(E_/T);
// Variables
dimensionedScalar nu0_;
dimensionedScalar E_;
volScalarField nu_;
Old   July 28, 2014, 16:43
Cyp
Cyprien
and are you sure that E_ and T have the same dimension ?
Old   July 28, 2014, 18:16
Thank you for help me.
It's worked
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
Dynamic Viscosity at transportproperties dictionary NickolasPl Main CFD Forum 0 June 2, 2011 14:06
Question to turbulence viscosity ratio Claud FLUENT 0 October 17, 2006 01:18
Question...Turbulence Intensity & Viscosity ratio Jay FLUENT 1 October 6, 2005 04:41
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 06:13
