number of cells in each direction
Like Tree1Likes
  • 1 Post By chrisb2244
Old   August 24, 2014, 12:31
Default number of cells in each direction
fshak92 is on a distinguished road
Assume that i have a simple cubic domain with Cartesian grids.
Does anybody know how i can access these values, either with a function, or accessing to the 'blockMeshDict' file.
1) number of cells in each direction. I know mesh.nCells() or mesh.cells().size() returns the total number of cells, but i need the number in each direction.
2) length of the domain (x, y and z)
3) length of cells edges in each direction to have dx, dy and dz.(the cells are uniform in each direction)
(at the moment, i compute dx, dy and dz by computing the distance between cell's centers, but i'm looking for any other ways)
Of course, either (1) or (2) can solve my problem, because having two of those three cases can be used to evaluate the remained one.
Tnx,
fshak92 is offline   Reply With Quote
Old   August 24, 2014, 22:40
Christian Butcher
chrisb2244 is on a distinguished road
If you have access to the polyMesh object, then
 meshObject.edges()[edgeLabel].mag()
returns the scalar length of the edge indexed by the variable 'edgeLabel'. If your edges are all the same length, then that should sort your problems. If only your edges in each direction are the same, then you'll need an edge for each direction.
Using
 labelList listOfCellEdges(meshObject.cEdges()[cellLabel]);
forAll(listOfCellEdges, edgeI)
   // Iterate through the edges of cellI, which if your cells are uniform,
   // can be any cell
   // Use meshObject.edges()[edgeI].vec() to get the vector along the edge, or
   // meshObject.edges()[edgeI].mag() to get it's magnitude.
Comparing these with the directions you're interested in shouldn't be too hard, I don't think. Then you just need to selectively store the ones you're interested in (eg first x, first y, first z direction).
If your region is cube/cuboid, then you can get the range of the directions by taking
vector extent(mesh_.cellCentres[mesh_.nCells()] - mesh_.cellCentres[0]);
extent += vector(dx, dy, dz) // where dx,y,z are set already,
// since these take cell centres...
scalar sizeInXDirection = extent[0]; //etc
fshak92 likes this.
chrisb2244 is offline   Reply With Quote
Old   August 26, 2014, 02:35
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
Are you trying to replicate a structured code on the unstructured FV method, implemented in OpenFOAM?
Blog: sourceflux.de/blog
"The OpenFOAM Technology Primer": sourceflux.de/book
Twitter: @sourceflux_de
Interested in courses on OpenFOAM?
jhoepken is offline   Reply With Quote
Old   August 26, 2014, 04:38
No,for different purpose.
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
Getting crazy with all the problems I have in OpenFoam Nicacio OpenFOAM Running, Solving & CFD 7 June 9, 2014 19:08
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 15:03
[Other] Number of cells in each direction IvanaS OpenFOAM Meshing & Mesh Conversion 3 April 16, 2013 06:05
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
