Problem with binary file
Old   February 16, 2015, 16:36
Default Problem with binary file
Tobi's Avatar
Tobias Holzmann
I want to open a binary file with FOAM Classes but I fail and I do not know why. The code is working with the following:
char tag[40];
std::fstream is;
is.open("Filename", std::ios::in | std::ios:binary);
is.read(tag, sizeof(tag));
Info<< tag << "\n";
Output is -> version.
If I replace it with Foam classes like:
char tag[40]
fileName name_ = "Filename";
IFstream is(name_, IFstream::BINARY);
Output is:
--> FOAM FATAL IO ERROR:
Expected a '(' while reading binaryBlock, found on line 1 the word 'version'
I will use the first version now but do anybody know where is my mistake? Thanke in advance.
Keep foaming,
Tobias Holzmann
Old   March 5, 2015, 17:36
Dongyue Li
sharonyue is on a distinguished road
maybe convert binary into ASCII then do your job? haha.
sharonyue is offline   Reply With Quote
Old   March 5, 2015, 21:31
Tobi's Avatar
Tobias Holzmann
Let me know how?!
The binary file is closed and is generated by a closed source ...
Nontheless I solved the problem!
Keep foaming,
Tobias Holzmann
Old   March 6, 2015, 02:23
Dongyue Li
Originally Posted by Tobi View Post
Let me know how?!
foamFormatConvert can do this job.
oh, maybe this will not work on your case.
Anyway, U already did it. Good luck!
Old   March 6, 2015, 06:01
Tobi's Avatar
Tobias Holzmann
i think foamFormatConvert only works with the OpenFOAM Files
Keep foaming,
Tobias Holzmann
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 19:43
Problem compiling a custom Lagrangian library brbbhatti OpenFOAM Programming & Development 2 July 7, 2014 11:32
[swak4Foam] funkySetFields compilation error tayo OpenFOAM Community Contributions 39 December 3, 2012 05:18
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
