viscoelasticinterfoam installation error
Old   December 18, 2013, 06:35
Default viscoelasticinterfoam installation error
thejaraju
thejaraju is on a distinguished road
Hi foamers
This theja from bangalore,
as i am working on the viscoelasticinterfoam to install this are the error generated during the installation
theja@theja:~/OpenFOAM/OpenFOAM-2.2.x/applications/solvers/viscoelasticInterFoam$ wmake && cd -
Making dependency list for source file viscoelasticInterFoam.C
SOURCE=viscoelasticInterFoam.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/transportModels -I/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/transportModels/incompressible/lnInclude -I/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/transportModels/interfaceProperties/lnInclude -I/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/meshTools/cellDist -I/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/fvMesh/wallDist -I/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/lnInclude -I./../viscoelasticTwoPhaseModels/lnInclude  -IlnInclude -I. -I/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/OpenFOAM/lnInclude -I/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/viscoelasticInterFoam.o
In file included from viscoelasticInterFoam.C:75:0:
alphaEqnSubCycle.H: In function ‘int main(int, char**)’:
alphaEqnSubCycle.H:3:15: error: ‘piso’ was not declared in this scope
/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’ [-Wunused-variable]
/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’ [-Wunused-variable]
/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/lnInclude/readPISOControls.H:6:15: warning: unused variable ‘nCorr’ [-Wunused-variable]
/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/lnInclude/readPISOControls.H:12:16: warning: unused variable ‘momentumPredictor’ [-Wunused-variable]
/home/theja/OpenFOAM/OpenFOAM-2.2.x/src/finiteVolume/lnInclude/readTimeControls.H:38:8: warning: unused variable ‘maxDeltaT’ [-Wunused-variable]
make: *** [Make/linux64GccDPOpt/viscoelasticInterFoam.o] Error 1
theja@theja:~/OpenFOAM/OpenFOAM-2.2.x/applications/solvers/viscoelasticInterFoam$ ^C
So please help me in sorting out the error
Thanking you in advance
Thejaraju
thejaraju is offline   Reply With Quote
Old   December 25, 2013, 13:30
Retired Super Moderator
Bruno Santos
Hi thejaraju,
Without access to the source code, it's a bit complicated to help you.
Nonetheless, given the error message, it seems that the problem is related to a change made in the way the "piso" variable was created in the past in older OpenFOAM versions and how it is created now in the current versions.
For example, if I run this command from the "~/OpenFOAM" folder, where I have all of my installations:
diff -Nur OpenFOAM-1.7.x/src/finiteVolume/cfdTools/general/include/readPISOControls.H OpenFOAM-2.2.x/src/finiteVolume/cfdTools/general/include/readPISOControls.H
I get this output:
--- OpenFOAM-1.7.x/src/finiteVolume/cfdTools/general/include/readPISOControls.H    2010-10-31 11:54:06.000000000 +0000
+++ OpenFOAM-2.2.x/src/finiteVolume/cfdTools/general/include/readPISOControls.H    2013-03-09 23:25:49.000000000 +0000
@@ -1,15 +1,17 @@
-    dictionary piso = mesh.solutionDict().subDict("PISO");
+    const dictionary& pisoDict = mesh.solutionDict().subDict("PISO");
-    int nCorr(readInt(piso.lookup("nCorrectors")));
+    const int nOuterCorr =
+        pisoDict.lookupOrDefault<int>("nOuterCorrectors", 1);
-    int nNonOrthCorr =
-        piso.lookupOrDefault<int>("nNonOrthogonalCorrectors", 0);
+    const int nCorr =
+        pisoDict.lookupOrDefault<int>("nCorrectors", 1);
-    bool momentumPredictor =
-        piso.lookupOrDefault<Switch>("momentumPredictor", true);
+    const int nNonOrthCorr =
+        pisoDict.lookupOrDefault<int>("nNonOrthogonalCorrectors", 0);
-    bool transonic =
-        piso.lookupOrDefault<Switch>("transonic", false);
+    const bool momentumPredictor =
+        pisoDict.lookupOrDefault("momentumPredictor", true);
+    const bool transonic =
+        pisoDict.lookupOrDefault("transonic", false);
-    int nOuterCorr =
-        piso.lookupOrDefault<int>("nOuterCorrectors", 1);
As you can see, the variable name "piso" has been changed to "pisoDict". Similarly, several other variables were renamed as well, as shown in the comparison of lines that start with a minus "-" and those with a plus "+".
Best regards,
Bruno
Old   April 13, 2015, 14:02
Unhappy ???\
arash
arash.heidarian is on a distinguished road
what is gamma in this solver?
arash.heidarian is offline   Reply With Quote
Old   April 16, 2015, 03:55
Sasa Goran
Supersale is on a distinguished road
I think this is the liquid phase? alpha1 in newer versions
Supersale is offline   Reply With Quote
Old   April 17, 2015, 10:22
arash
thank you..
yes it is alpha1...
my problem is how adjust the transportproperties file...
Old   April 19, 2015, 20:39
Sasa Goran
I have found one case file for this solver on sourceforge (http://sourceforge.net/projects/viscoelasticof/). In this case file the transportProperties file is the same as for interFoam, but there is a viscoelasticProperties file. If you happen to have another case file for this solver, please share as i, too, am struggling to make sense of all of this
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 00:10
Problem running perturbUCyl sen.1986 OpenFOAM 17 June 4, 2019 05:56
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 05:18
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
user defined function cfduser CFX 0 April 29, 2006 10:58
