heat transfer from fluid to a solid
Old   April 27, 2015, 11:05
Default heat transfer from fluid to a solid
Laurent DASTUGUE
laurentD is on a distinguished road
Hi foamers,
i am currently trying to understand how does OpenFOAM calculate the heat flux from a fluid to a solid. I know that the correct relation is : Phi = -h grad T but i don't find the part of the programmed code which is linked to the calculation of the heat flux, or linked to the way does OpenFOAM calculate the value of the h.
Can anybody help me, showing me the way to attain these informations ?
Thank you very much.
Laurent
laurentD is offline   Reply With Quote
Old   May 4, 2015, 09:06
Laurent DASTUGUE
Nobody is working with fluid and solid parts ?
I can't believe that...
I just need the location where i can find the calculation of the heat transfer between solid and fluid.
Currently i am searching into the program but if anybody can help me...
Have a good day,
Laurent
Old   May 4, 2015, 09:56
Naveed Iqbal
niqbal is on a distinguished road
hi laurentD,
you need to be more precise. What kind of flow it is? As there are different approaches for different flows; are you doing multiphase or siingle phase. If that is a single phase and you are looking for heat transfer between solid and fluid you may have a look in solvers chtMultiRegionFoam/solid.
If you are looking for heat transfer from fluid to solid, then you need to look in multiphase solvers and relevant heat transfer models.
niqbal is offline   Reply With Quote
Old   May 4, 2015, 10:25
Laurent DASTUGUE
Hi Niqbal,
i work with a single phase flow, and i use the solver chtMultiRegionFoam.
But when i loook into the programs in the directories under chtMultiRegionFoam/ i don't find the one which calculates the heat transfer between my hot fluid and my cold solid, neither under fluid/ nor solid/.
This is why i want to know if there is another location where i should search.
Or maybe the solution is here but i don't recognize it.
Thank you very much for your answer.
Laurent
Old   May 4, 2015, 11:01
Naveed Iqbal
hi Laurent,
have a look in ../solid/setRegionSolidFields.H and ../solid/solveSolid.H and energy equation in fluid folder.
Cheers,
Naveed
Old   May 6, 2015, 09:11
Laurent DASTUGUE
I have look these two files. But i am not an expert on C++-programming.
Does it seem that OF use the enthalpy to make the heat transfer ?
Old   May 6, 2015, 10:03
Laurent DASTUGUE
In fact, i am trying to do the following thing :
1/ Do a cinematic calculation with a fluid going inside a solid, without thermic calculations.
2/ Do a thermic job, using results from the first job as inputs (like the h convection coefficient for example).
But i have the impression that the h convection coefficient between fluid and solid isn't calculated by OpenFOAM. Does anybody have an idea to help me to build a job as i want. Maybe using phi ?...
Best regards,
Laurent
which solver (tutorial) is for heat transfer between fluid and solid? mxylondon OpenFOAM 3 December 14, 2012 19:54
Solid / Fluid Heat Transfer Koranten FLUENT 3 March 19, 2011 07:21
modeling heat transfer betwwen fluid and solid Al Mazdeh CFX 0 March 13, 2008 10:35
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
