Actuator Disk Implementation Problem
Old   June 25, 2015, 03:43
Default Actuator Disk Implementation Problem
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hi All,
I am trying to follow a report that was about the "Actuator Disk Method". It is an interesting topic to learn. I have read the report until page 7, and then I have tried to apply what is been done in the report. However, I have faced some difficulties match it to OpenFoam 2.3.2 since it was made in the old version 1.5. I am asking if anybody of you by any chance run through the steps and find sometime to help out in this regard.
http://www.tfd.chalmers.se/~hani/kur...ningReport.pdf
Here is "the error"what I got when I ran blockMesh and simpleFoam:
"--> FOAM FATAL IO ERROR:
Cannot find patchField entry for cyclic fan_half0
Is your field uptodate with split cyclics?
Run foamUpgradeCyclics to convert mesh and fields to split cyclics.
file: /home/tariq/windturbine/project3/erikSvenningFiles/fan/0/p.boundaryField from line 34 to line 59.
From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
in file /home/tariq/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 192.
FOAM exiting
Thank you in advance
tareqkh is offline   Reply With Quote
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
k epsilon model implementation problem jyothishkumar Main CFD Forum 0 July 19, 2011 09:39
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
