Problems with running a custom solver: "Unknown psiCombustionModel" |
#21 |
A. Kamitsis
Rep Power: 10 ![]() |
Hi Bruno,
I have encountered another issue and hope you may be able to point me in the right direction. My simulations have been running quite well however when I go to run a fixed-density case in parallel I'm getting the following error: running: Code:
mpirun -np 8 rotatingCDFireFoam -parallel Code:
alexei@alexei-OptiPlex-9010:~/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w$ mpirun -np 8 rotatingCDFireFoam -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.0 Exec : rotatingCDFireFoam -parallel Date : Oct 01 2015 Time : 03:17:49 Host : "alexei-OptiPlex-9010" PID : 7672 Case : /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w nProcs : 8 Slaves : 7 ( "alexei-OptiPlex-9010.7673" "alexei-OptiPlex-9010.7674" "alexei-OptiPlex-9010.7675" "alexei-OptiPlex-9010.7676" "alexei-OptiPlex-9010.7677" "alexei-OptiPlex-9010.7678" "alexei-OptiPlex-9010.7679" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model infinitelyFastChemistry<psiThermoCombustion,gasThermoPhysics> Selecting thermodynamics package { type hePsiThermo; mixture singleStepReactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader foamChemistryReader Fuel heat of combustion :5.00312e+07 stoichiometric air-fuel ratio :17.0854 stoichiometric oxygen-fuel ratio :3.98918 Maximum products mass concentrations: H2O: 0.124183 CO2: 0.151685 N2: 0.724132 Combustion mode: explicit Reading thermophysical properties Creating component thermo properties: multi-component carrier - 5 species [2] [4] [6] [7] [7] [4] [4] --> FOAM FATAL IO ERROR: [4] Cannot find patchField entry for procBoundary4to0 [4] [6] [6] --> FOAM FATAL IO ERROR: [6] Cannot find patchField entry for procBoundary6to2 [6] [6] file: [7] --> FOAM FATAL IO ERROR: [7] Cannot find patchField entry for procBoundary7to3 [7] [7] file: /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w/processor7/../constant/rho.boundaryField from line 25 to line 43. [7] [7] From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) [7] in file /opt/openfoam220/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. [7] FOAM parallel run exiting [7] [2] [2] --> FOAM FATAL IO ERROR: [2] Cannot find patchField entry for procBoundary2to0 [2] [2] file: /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w/processor2/../constant/rho.boundaryField from line 25 to line 43. [2] [2] From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) [2] in file /opt/openfoam220/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. [2] FOAM parallel run exiting [2] /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w/processor6/../constant/rho.boundaryField from line 25 to line 43. [6] [6] From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) [6] in file /opt/openfoam220/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. [6] FOAM parallel run exiting [6] [4] file: /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w/processor4/../constant/rho.boundaryField from line 25 to line 43. [4] [4] From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) [4] in file /opt/openfoam220/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. [4] FOAM parallel run exiting [4] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [1] [1] [1] --> FOAM FATAL IO ERROR: [1] Cannot find patchField entry for procBoundary1to0 [1] [1] file: /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w/processor1/../constant/rho.boundaryField from line 25 to line 43. [1] [1] From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) [1] in file /opt/openfoam220/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. [1] FOAM parallel run exiting [1] [5] [5] [5] --> FOAM FATAL IO ERROR: [5] Cannot find patchField entry for procBoundary5to1 [5] [5] file: /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w/processor5/../constant/rho.boundaryField from line 25 to line 43. [5] [5] From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) [5] in file /opt/openfoam220/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. [5] FOAM parallel run exiting [5] no liquid components no solid components Creating field rho [0] [0] [0] --> FOAM FATAL IO ERROR: [0] Cannot find patchField entry for procBoundary0to1 [0] [0] file: /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w/processor0/../constant/rho.boundaryField from line 25 to line 43. [0] [0] From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) [0] in file /opt/openfoam220/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. [0] FOAM parallel run exiting [0] [3] [3] [3] --> FOAM FATAL IO ERROR: [3] Cannot find patchField entry for procBoundary3to1 [3] [3] file: /home/alexei/OpenFOAM/alexei-2.2.0/my_cases/flame_1/whirl/changing_diff/constant_density/whirl_0.05r_0.01in_3.0w/processor3/../constant/rho.boundaryField from line 25 to line 43. [3] [3] From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) [3] in file /opt/openfoam220/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 154. [3] FOAM parallel run exiting [3] -------------------------------------------------------------------------- mpirun has exited due to process rank 0 with PID 7672 on node alexei-OptiPlex-9010 exiting improperly. There are two reasons this could occur: 1. this process did not call "init" before exiting, but others in the job did. This can cause a job to hang indefinitely while it waits for all processes to call "init". By rule, if one process calls "init", then ALL processes must call "init" prior to termination. 2. this process called "init", but exited without calling "finalize". By rule, all processes that call "init" MUST call "finalize" prior to exiting or it will be considered an "abnormal termination" This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [alexei-OptiPlex-9010:07671] 7 more processes have sent help message help-mpi-api.txt / mpi-abort [alexei-OptiPlex-9010:07671] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages Kindest Regards, Alexei |
#22 |
Retired Super Moderator
Bruno Santos
Rep Power: 127 ![]() ![]() ![]() ![]() ![]() ![]() |
Hi Alexei,
Mmm... that kind of error message occurs when you copy a field file from the main "0" folder into the "processor*/0" folders. I say this because the utility decomposePar will create those boundaries for you in the field files, which in your case, is the "rho" file that is missing the boundary entries. If you really want to copy the field files from the main "0" folder to the "processor*/0" folders, then you should add this entry to all files: Code:
"proc.*" { type processor; } Best regards, Bruno
#23 |
A. Kamitsis
Hi Bruno,
If I did not want to copy the field files to the processor folders how would I get around the problem? I currently have my constant rho as follows: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "constant"; object rho; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -3 0 0 0 0 0]; internalField uniform 1; boundaryField { outer_boundary { type fixedValue; value uniform 1; } floor { type fixedValue; value uniform 1; } top { type fixedValue; value uniform 1; } hotspot { type fixedValue; value uniform 1; } } Alexei |
#24 |
Bruno Santos
Quick answer: Ah, OK, the field file "rho" is in the folder "constant". Then try running decomposePar like this:
decomposePar -constant If this doesn't work, then you must place the "rho" file in the time folder, even if the field doesn't change during the simulation. You will also need to modify the solver accordingly. |
#25 | |
Fengjiao Bian
Rep Power: 11 ![]() |
Hi Bruno,I changed my files in the 0.original folder as the case "motobike" .Then I decomposed. It still didn't generate the 0 folders in all processors.Could you tell me how to do it? The starttime of my controlDict is 0.
#26 | |
Fengjiao Bian
Hi,Bruno.I have solved the problem, your method is quite well, the problem is the wrong boundary.Thanks!
Display Modes | |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 07:54 |
Segmentation fault running waveDyMFoam solver (mod. interDyMFoam solver - waves2Foam) | Ed R | OpenFOAM Running, Solving & CFD | 5 | July 2, 2013 11:36 |
Problems running customized solver for diffusion | mmkr825 | OpenFOAM Running, Solving & CFD | 1 | August 30, 2012 14:01 |
problem in running a modified solver | adambarfi | OpenFOAM | 5 | August 10, 2012 15:52 |
CFX 5.5 | Roued | CFX | 1 | October 2, 2001 16:49 |
