Give the file the proper header for being used as TimeVaryingMappedFixedValue input
Like Tree3Likes
  • 2 Post By syavash
  • 1 Post By Likun
Old   October 9, 2015, 19:01
Default Give the file the proper header for being used as TimeVaryingMappedFixedValue input
Syavash Asgari
syavash is on a distinguished road
Hi Foamers,
In the file foamFileSurfaceWriter.C in "src/sampling/sampledSurface/writers/foamFile" , I can see the following line
   // values
    OFstream(valuesDir/fieldName)()  << values;
which prints the sampled field, e.g. U as the output. I should sample velocity at the inlet BC at each time step, during a very long time. In this way, I would have a huge number of time folders, yet lacking the OpenFOAM header (just vector values and coordinates).
I want to feed these time series into another simulation as boundary condition using TimeVaryingMappedFixedValue BC. But this BC demands for input files with headers.
Unfortunately, it is not possible to add header to each file manually, because the number is huge!
I have tried something like the following code to add the proper header, but without success:
vectorAverageField values
    IOobject
        "values",
        runTime.constant()/valuesDir/fieldName,
        mesh,
        IOobject::NO_READ,
        IOobject::NO_WRITE
       ,facesSet.size()
        values.write()
the following error appears when compiling:
SOURCE=sampledSurface/writers/foamFile/foamFileSurfaceWriter.C ;  g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-100 -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/finiteVolume/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/meshTools/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/surfMesh/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/fileFormats/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/triSurface/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/conversion/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/OpenFOAM/lnInclude -I/home/syavash/OpenFOAM/OpenFOAM-2.3.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/foamFileSurfaceWriter.o
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C: In member function ‘void Foam::foamFileSurfaceWriter::writeTemplate(const Foam::fileName&, const Foam::fileName&, const pointField&, const faceList&, const Foam::word&, const Foam::Field<Type>&, bool, bool) const’:
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:82:6: error: ‘vectorAverageField’ was not declared in this scope
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:82:25: error: expected ‘;’ before ‘values’
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:96:1: error: expected ‘;’ before ‘}’ token
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C: In instantiation of ‘void Foam::foamFileSurfaceWriter::writeTemplate(const Foam::fileName&, const Foam::fileName&, const pointField&, const faceList&, const Foam::word&, const Foam::Field<Type>&, bool, bool) const [with Type = double; Foam::pointField = Foam::Field<Foam::Vector<double> >; Foam::faceList = Foam::List<Foam::face>]’:
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:157:1:   required from here
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:95:9: error: ‘const class Foam::Field<double>’ has no member named ‘write’
         values.write()
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C: In instantiation of ‘void Foam::foamFileSurfaceWriter::writeTemplate(const Foam::fileName&, const Foam::fileName&, const pointField&, const faceList&, const Foam::word&, const Foam::Field<Type>&, bool, bool) const [with Type = Foam::Vector<double>; Foam::pointField = Foam::Field<Foam::Vector<double> >; Foam::faceList = Foam::List<Foam::face>]’:
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:95:9: error: ‘const class Foam::Field<Foam::Vector<double> >’ has no member named ‘write’
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C: In instantiation of ‘void Foam::foamFileSurfaceWriter::writeTemplate(const Foam::fileName&, const Foam::fileName&, const pointField&, const faceList&, const Foam::word&, const Foam::Field<Type>&, bool, bool) const [with Type = Foam::SphericalTensor<double>; Foam::pointField = Foam::Field<Foam::Vector<double> >; Foam::faceList = Foam::List<Foam::face>]’:
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:95:9: error: ‘const class Foam::Field<Foam::SphericalTensor<double> >’ has no member named ‘write’
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C: In instantiation of ‘void Foam::foamFileSurfaceWriter::writeTemplate(const Foam::fileName&, const Foam::fileName&, const pointField&, const faceList&, const Foam::word&, const Foam::Field<Type>&, bool, bool) const [with Type = Foam::SymmTensor<double>; Foam::pointField = Foam::Field<Foam::Vector<double> >; Foam::faceList = Foam::List<Foam::face>]’:
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:95:9: error: ‘const class Foam::Field<Foam::SymmTensor<double> >’ has no member named ‘write’
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C: In instantiation of ‘void Foam::foamFileSurfaceWriter::writeTemplate(const Foam::fileName&, const Foam::fileName&, const pointField&, const faceList&, const Foam::word&, const Foam::Field<Type>&, bool, bool) const [with Type = Foam::Tensor<double>; Foam::pointField = Foam::Field<Foam::Vector<double> >; Foam::faceList = Foam::List<Foam::face>]’:
sampledSurface/writers/foamFile/foamFileSurfaceWriter.C:95:9: error: ‘const class Foam::Field<Foam::Tensor<double> >’ has no member named ‘write’
make: *** [Make/linux64GccDPOpt/foamFileSurfaceWriter.o] Error 1
Is there any way to solve this problem and adding the proper header to the files generated through the sampling??
Thanks,
Syavash
uckmhnds and HeleShawman like this.
syavash is offline   Reply With Quote
Old   October 12, 2015, 07:43
Syavash Asgari
Anyone who might be interested?? This is a real problem for me since I need inlet velocity at each time step to be saved and used as boundary condition for another LES simulation!
I also checked sample utility but it similarly only saves values and generates no header!
TimeVaryingMappedFixedValue demands a header for velocity like this:
|  \\    /   O peration     | Version:  2.3.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       vectorAverageField;
    object      values;
How can I generate a header like one in above for my sampled inlet boundary??
Thanks,
Syavash
Old   October 12, 2015, 07:46
Syavash Asgari
[CODE]
FoamFile
    version     2.0;
    format      ascii;
    object      values;
Thanks,
Syavash
Old   October 13, 2015, 07:28
Syavash Asgari
No one can help me??!
I am really stuck in this!
Old   October 15, 2015, 04:23
Likun
Likun is on a distinguished road
Send a message via Skype™ to Likun
Dear Syavash,
I also met similar problem before, and I have written a matlab script to add the head to the sampled file.
Suppose your sampleDict reads like this:
|  \\    /   O peration     | Version:  2.1.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      sampleDict;
//Example to output facecentres, faces and points for the selected patches
interpolationScheme cellPoint;
surfaceFormat foamFile;
surfaces
        mySampleSurface
                type           plane;
                basePoint      (0.01 0.0 0.0);
                normalVector   (1.0 0.0 0.0);
//      type      patch;
//      patches  (OUTLET);
//Not really required when run before a simulation as the velocity will be empty.
fields          ( U );
After sample you will have many timestep folders under the directory: 'xx/postProcessing/surfaces/' and within each timestep folder you have the sampled surface 'mySampleSurface/'.
Here is the matlab script that I used to add the header and to move the required files directly under the timestep folder.
num_time = 9; % Total number of timestep folders
stp_time = 1e-4;         % size of timestep
case_dir = 'xx/postProcessing/surfaces/';
for i = 1:num_time
    time_dir = (i-1)*stp_time;
    old_dir = strcat(case_dir, num2str(time_dir), '/mySampleSurface/vectorField/');
    new_dir = strcat(case_dir, num2str(time_dir), '/');
    fid = fopen([new_dir 'header'],'w');
    fprintf(fid,'/*--------------------------------*- C++ -*----------------------------------*\\');
    fprintf(fid,'\n| =========                 |                                                 |');
    fprintf(fid,'\n| \\      /  F ield          | OpenFOAM: The Open Source CFD Toolbox           |');
    fprintf(fid,'\n|  \\    /   O peration      | Version:  2.3.x                                 |');
    fprintf(fid,'\n|   \\  /    A nd            | Web:      http://www.OpenFOAM.com               |');
    fprintf(fid,'\n|    \\/     M anipulation   |                                                 |\n');
    fprintf(fid,'\\*---------------------------------------------------------------------------*/');
    fprintf(fid,'\nFoamFile \n{\n');
    fprintf(fid,'   version     2.0;\n');
    fprintf(fid,'   format      ascii;\n');
    fprintf(fid,'   class       vectorAverageField;\n');
    fprintf(fid,'   location    "constant/boundaryData/mySampleSurface/%s";\n', num2str(time_dir));
    fprintf(fid,'   object      U;\n}\n');
    fprintf(fid,'// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * //');
    fprintf(fid,'\n\n');
    fprintf(fid,'//Average\n');
    fprintf(fid,'(0 0 0)\n');
    fclose(fid);
    system(sprintf('%s %s%s %s%s', 'cp', old_dir, 'U', new_dir, 'U.org'));
    system(sprintf('%s %s%s %s%s %s %s%s', 'cat', new_dir, 'header', new_dir, 'U.org', '>', new_dir, 'U'));
    system(sprintf('%s %s%s', 'rm', new_dir, 'U.org'));
    system(sprintf('%s %s%s', 'rm', new_dir, 'header'));
end
system(sprintf('%s %s%s %s%s', 'cp', new_dir, 'mySampleSurface/faceCentres', case_dir, 'points.org'));
fid = fopen([case_dir 'header'],'w');
fprintf(fid,'   class       vectorField;\n');
fprintf(fid,'   object      points;\n}\n');
fprintf(fid,'\n');
fclose(fid);
system(sprintf('%s %s%s %s%s %s %s%s', 'cat', case_dir, 'header', case_dir, 'points.org', '>', case_dir, 'points'));
system(sprintf('%s %s%s', 'rm', case_dir, 'points.org'));
system(sprintf('%s %s%s', 'rm', case_dir, 'header'));
for i = 1:num_time
    system(sprintf('%s %s %s%s', 'rm', '-r', new_dir, 'mySampleSurface'));
    system(sprintf('%s %s %s%s', 'rm', '-r', new_dir, 'vectorField'));
end
After this you can copy the folder ''mySampleSurface" to the ''constant/boundaryData" of your new case.
Hope this helps.
Best,
Likun
uckmhnds likes this.
Likun is offline   Reply With Quote
Old   October 20, 2015, 14:09
Syavash Asgari
Originally Posted by Likun View Post
Dear Syavash,
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      sampleDict;
surfaces
        mySampleSurface
                type           plane;
//      type      patch;
fields          ( U );
for i = 1:num_time
    fclose(fid);
end
fprintf(fid,'\n');
fclose(fid);
for i = 1:num_time
end
Hope this helps.
Best,
Likun
Dear Likun,
Thank you for sharing your solution.
Unfortunately, Matlab could not recognize 'cp' and 'rm' commands in your scrip! But I am aware that this is an issue with the version installed on my PC!
I could find a workaround. I could make the solver (pimpleFoam) to write the sampled plane (inlet bc) at each time steps. In this way, OpenFoam automatically generates a header with class vectorField just like the following:
FoamFile
    version     2.0;
    format      ascii;
    class       vectorField;
    location    "constant/boundaryData/inlet/0.2";
    object      U;
Then, I replaced keyword vectorField with vectorAverageField and '960'with '(0 0 0) 960', (960 is the number of faces in inlet bc) respectively using the following commands in linux terminal:
find ./ -type f -readable -writable -exec sed -i '0,/vectorField/s/vectorField/vectorAverageField/' {} \;
find ./ -type f -readable -writable -exec sed -i '0,/960/s/960/(0 0 0) 960/' {} \;
These command find and replace the desired keywords. The option '-i' allows the command 'sed' to be executed as 'in place', i.e. find a file in a folder, open and replace the desired word, save and then close to continue searching for another file.
Regards,
Syavash
Old   January 11, 2016, 09:16
Ali
ali.m.1 is on a distinguished road
Originally Posted by syavash View Post
Dear Likun,
FoamFile
    version     2.0;
    format      ascii;
    class       vectorField;
    object      U;
Regards,
Syavash
Hi
If you got this to work, do you think it would be possible to run both simulations simultaneously?
So the 'inlet' BC reads the 'outlet' BC while the solver is running?
ali.m.1 is offline   Reply With Quote
Old   January 12, 2016, 11:57
Tomislav Maric
tomislav_maric is on a distinguished road
The IOobject class has the member functions writeHeader and readHeader that write the appropriate headers to streams. Since files are abstracted as streams in C++, we can use the IOobject class to write a header to a file. Here is how the application looks like:
#include "fvCFD.H"
// Main program:
int main(int argc, char *argv[])
    #include "setRootCase.H"
    #include "createTime.H"
    IOobject myObject
        "widget",
        runTime.timeName(),
        runTime,
        IOobject::NO_READ,
        IOobject::NO_WRITE
    // Write the header to the output stream.
    myObject.writeHeader(Info);
    // Write the header to a file.
    OFstream headerFile("myFile");
    myObject.writeHeader(headerFile);
    Info<< "\nEnd\n" << endl;
    return 0;
When executed, it will write the header to the output stream, using the global messageStream Info object, and also to the output file stream (file), named "myFile".
If you want to change the parameters of the header, change the IOobject constructor arguments.
When asking a question, prepare a SSCCE.
tomislav_maric is offline   Reply With Quote
Old   January 12, 2016, 12:56
Syavash Asgari
Hi
Ali,
I am not really sure. The above-mentioned solution makes me able to perform a precursor simulation before doing the primary simulation.Adding that my computational resource does not allow me to have two simultaneous simulations!
Besides, I think it is the most appropriate solution for me to save data on a plane in advance, since I would be able to implement the data for as many simulations as I want to perform.
Regards
Old   January 13, 2016, 08:15
Ali
Thanks Syavash
I'm planning on trying something like that, but it looks like it's going to be difficult!
regards
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 17:25
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
