Temperature dependent incompressible viscosity model |
October 14, 2015, 12:11 |
Nikolai Tauber
Rep Power: 10 |
Dear Foamers,
I am currently working on a temperature dependent viscosity model for a modified solver based on simpleFoam and buoyantBuossinesqSimpleFoam. I am planning on using the powerLaw viscosity as base for modification. Therefore, I have made a copy of it to: Code:
OpenFOAM/user-2.3.x/src/transportModels/incompressible/viscosityModels/nuTemperature Code:
nuTemperature.C Code:
nuTemperature.H Code:
nuTemperature.C LIB = $(FOAM_USER_LIBBIN)/libusernuTemperature Code:
EXE_INC = \ -I$(LIB_SRC)/transportModels/incompressible/lnInclude/ \ -I$(LIB_SRC)/finiteVolume/lnInclude LIB_LIBS = -lfiniteVolume Code:
libs ("libusernuTemperature.so"); Code:
Build : 2.3.x-6b18d98df2bc Exec : nuTemperatureSimpleFoam Date : Oct 14 2015 Time : 18:05:36 Host : "hulk2.iha.dk" PID : 34454 Case : /home/dan/run/151009singleCylinder_tvsf_testCase nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Duplicate entry powerLaw in runtime selection table viscosityModel #0 /usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+0x27) [0x7f076e59a207] #1 /usr/local/OpenFOAM/OpenFOAM-2.3.x/platforms/linux64GccDPOpt/lib/libincompressibleTransportModels.so(_ZN4Foam14viscosityModel31adddictionaryConstructorToTableINS_15viscosityModels8powerLawEEC1ERKNS_4wordE+0xce) [0x7f076e91ce1e] #2 /home/dan/OpenFOAM/dan-2.3.x/platforms/linux64GccDPOpt/lib/libusernuTemperature.so(+0x15ee9) [0x7f0769871ee9] #3 /home/dan/OpenFOAM/dan-2.3.x/platforms/linux64GccDPOpt/lib/libusernuTemperature.so(+0x18d66) [0x7f0769874d66] Create mesh for time = 0 Reading thermophysical properties Reading field T Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model nuTemperature --> FOAM FATAL ERROR: Unknown viscosityModel type nuTemperature Valid viscosityModels are : 5 ( BirdCarreau CrossPowerLaw HerschelBulkley Newtonian powerLaw ) From function viscosityModel::New(const volVectorField&, const surfaceScalarField&) in file viscosityModels/viscosityModel/viscosityModelNew.C at line 53. FOAM exiting ^Z [10]+ Stopped nuTemperatureSimpleFoam |
October 14, 2015, 12:41 |
It is not enough just to rename file, you have to correct this piece of code: Code:
... public: //- Runtime type information TypeName("powerLaw"); ... UPD. And surely you have to rename class. Last edited by alexeym; October 14, 2015 at 15:03. |
March 2, 2017, 09:08 |
Emery
Rep Power: 9 |
Hi foamers,
I'am working with simpleFoam, and I have implemented a new viscosity model based on the Herschel-Bulkley model. Through the forum I found several disussions (and documents) about the implementation of a new viscosity model in OpenFOAM. I followed all the tips and steps that are suggested there, but I still don't manage to run a case with my new viscosity model. I always got the error message posted by "niko08/07", suggesting that my new viscosity model is not valid. Can somebody give a step by step workflow to handle this issue? Any help would be well appreciated. Thanks in advance, and have a nice week. Regards. Last edited by TemC; March 3, 2017 at 03:33. |
Temperature dependent Viscosity using Power-Law | shikamaru | OpenFOAM Running, Solving & CFD | 3 | January 6, 2015 01:47 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
icoUncoupledKinematicParcelFoam: temperature dependent viscosity | 90nash | OpenFOAM Running, Solving & CFD | 5 | March 26, 2014 23:43 |
Temperature dependent now-newtonian viscosity | mozafarie | FLUENT | 2 | March 22, 2014 00:19 |
Temperature dependent Cp: JANAF tables vs Debye model | antb | OpenFOAM Running, Solving & CFD | 1 | August 26, 2013 16:57 |
