December 24, 2015, 04:20 |
how to customise "reactingFoam" solver
Rep Power: 10 |
Dear Sir,
I am trying to calculate a system including chemical reaction using reactingFoam solver, but I don't understand how to use this solver. Could you teach me the following questions? 1). Is it possible to describe a reaction rate equation in the constant/reactions file by myself, not choosing the "type"? And moreover, I want to describe parameters of the rate equation too. (Parameters are the function of pressure.) 2). Are "reaction->R(Yi) in YEqn.H calculated from the reaction rate equation? If so, can I use the result calculated by my described equation (above 1).) as R(Yi)? 3). Can I also use the result calculated by my described equation (above 1).) as "reaction->Sh()" in EEqn.H? 4). Calculation I want to do is not combustion reaction, but is the "constant/combustionProperties" file needed for the calculation? 5). Where is alpha (=k/cp) calculated? I think α must be calculated to calculated "αeff". Thanks in advance. KeiJun |
January 13, 2016, 03:16 |
Rep Power: 10 |
Dear Sir,
I keep trying to customize reactingFoam solver, and what I don't understand how to describe remains. I want to describe the reaction rate equation to UEqn.H, not refering the "type" on constant/reactions file. The reaction rate equation is ∂qi/∂t = ki(qi* - qi), where qi is the reaction amount of the specie i per catalyst (the unit of qi is mol/kg), and qi* is the equilibrium reaction amount per catalyst. I can compile myReactingFoam.C, in which I add the above rate equation. However, when I run the tutorials, the error of reaction type has come. Then I want to make the reaction rate file mensioned above in src/thermophysicalModels/specie/reaction/reactionRate(?), not to emerge the error. Alternatively, I want not to refer Reaction.C during running a tutorials, not to refer the type on constant/reactions. Could you teach me how to do? I am having a very hard time now. I am really looking forward to your reply. Sincerely, KeiJun |
Fluent Adjoint Solver? | ex10148 | FLUENT | 16 | September 28, 2018 08:11 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Divergence problem | Smaras | FLUENT | 13 | February 21, 2013 05:03 |
3d vof | Smaras | FLUENT | 2 | February 19, 2013 06:58 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
