Read in Formula via Dictionary
Old   January 23, 2016, 07:43
Default Read in Formula via Dictionary
hxaxtma is on a distinguished road
Hi guys,
quick question, I created an own Dict and reading in a formular via
word    cd(word(sensorDict.subDict("solving").lookup("cd")));
where cd is defined in the dict as:
cd            "1+10*Foam::exp(Re,0.66666667)";
Next I want to use this relation in my main loop, so I need to convert this word string to what exactly?
Thanks for help
hxaxtma is offline   Reply With Quote
Old   January 25, 2016, 03:28
Hi, I tried with
 #include <cstdlib>
scalar cd_form=atof(cd.c_str());
Code is now compiling and it is printing the formula as string, but not using it as mathematical operator.
Any ideas?
Old   January 25, 2016, 03:29
chriss85 will become famous soon enough
This means you will need to have a parser/interpreter. I'm not sure if there is one in OpenFOAM, yiou might have some luck with swak4Foam though.
chriss85 is offline   Reply With Quote
Old   January 27, 2016, 11:47
David Gaden
marupio is on a distinguished road
I think you might want equationReader.
swak4Foam could be suitable, but if you want to parse a user-entered equation and use it at your discretion within your application, then that is exactly what equationReader was intended for. Be careful, though... any interpreted equations will take longer to evaluate than hard-coded equations.
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Read properties per component from an input file dictionary Cyp OpenFOAM Programming & Development 29 November 1, 2015 21:41
Including lists in a dictionary. Divyaprakash OpenFOAM Programming & Development 0 June 18, 2015 06:14
writing subDict in a dictionary ubaid OpenFOAM Programming & Development 3 October 25, 2014 17:17
Reading a field(?) within a dictionary ecbmxer OpenFOAM Programming & Development 0 July 14, 2014 16:21
Overwriting dictionary from BC Phicau OpenFOAM Programming & Development 1 January 25, 2013 04:24
