Difference between solve() and solve(...finalInnerIter())?
Like Tree4Likes
  • 3 Post By jherb
  • 1 Post By akidess
Old   June 8, 2016, 06:01
Default Difference between solve() and solve(...finalInnerIter())?
Lennart
elmo555 is on a distinguished road
can you help me understand the difference between a simple call to
p_rghEqn.solve();
and
p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.finalInnerIter())));
Your help is much appreciated!
elmo555 is offline   Reply With Quote
Old   June 8, 2016, 17:59
Joachim Herb
jherb is on a distinguished road
The second version uses the settings for p_rghFinal in the system/fvSolutions file (for solver settings) for the last iteration in the pimple outer loop (so for the last iteration step per time step) whereas the first version *always* use the p_rgh settings. So the p_rghFinal settings are ignore in the first case.
jherb is offline   Reply With Quote
Old   June 9, 2016, 03:56
Lennart
Thanks for the quick and clear answer!
My settings for p_rgh and p_rghFinal are the same, except for the relTol, which is 0.05 and 0, respectively. So naturally, the solver needs more iterations in the last outer pimple loop because it can't stop at any relative tolerance. I was wondering if it's normal that THAT much more iterations are required:
DICPCG:  Solving for p_rgh, Initial residual = 0.0509331, Final residual = 0.00187709,
No Iterations 3
time step continuity errors : sum local = 9.11852e-06, global = 7.5083e-06, cumulative = -0.00101879
DICPCG:  Solving for p_rgh, Initial residual = 0.00738722, Final residual = 0.000365238,
No Iterations 80
time step continuity errors : sum local = 7.85558e-06, global = 7.48801e-06, cumulative = -0.0010113
DICPCG:  Solving for p_rgh, Initial residual = 0.00345672, Final residual = 9.48528e-08,
No Iterations 250
time step continuity errors : sum local = 7.50304e-06, global = 7.50295e-06, cumulative = -0.0010038
Or is this suggesting that there's another problem with my code?
Old   June 9, 2016, 04:30
Joachim Herb
It would say it is normal.
Old   June 9, 2016, 04:40
akidess's Avatar
Anton Kidess
Just look at your residuals. At first you are reducing them by 10, then in the final iteration 10'000x. Of course that will require a lot more iterations. By the way, GAMG typically shows much better performance for the solution of the pressure equation.
No Iterations 3
No Iterations 80
No Iterations 250
elmo555 likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
SIMPLE Algorithm Finite Difference Equations: how to discretize and solve? DA6righthand Main CFD Forum 0 August 3, 2015 12:12
Can OpenFoam solve this problem? salazardetroya OpenFOAM Running, Solving & CFD 1 July 29, 2015 22:34
Additional 2D solve at an inlet patch during each iteration of a usual 3D solve incompressible OpenFOAM Running, Solving & CFD 1 July 5, 2015 11:09
solve the scalar gradient yp5547 FLUENT 0 December 24, 2014 05:05
Difference between codes and representations titio OpenFOAM Running, Solving & CFD 3 July 3, 2009 07:58
