Fix the scalar variable in a rectangular region during simulation
Like Tree3Likes
  • 1 Post By alexeym
  • 1 Post By rapierrz
  • 1 Post By alexeym
Old   February 20, 2016, 11:03
Default Fix the scalar variable in a rectangular region during simulation
invadoria's Avatar
Ender Demirel
invadoria is on a distinguished road
Hi all.
I'm solving transport equation for a scalar variable C. I want to fix this scalar variable C in a rectangular region of the computational domain during simulation to keep the variable unchanged in this region during solution. Can you tell me how I can do it? Do I have to modify the source code?
Thank you in advance..
invadoria is offline   Reply With Quote
Old   February 20, 2016, 15:46
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Take a look at $FOAM_SRC/fvOptions/constraints/general/explicitSetValue. It uses fvMatrix::setValues (http://foam.sourceforge.net/docs/cpp...a6b05660da9bc2) to fix values in a cellSet.
invadoria likes this.
alexeym is offline   Reply With Quote
Old   February 21, 2016, 23:33
Hesam
rapierrz is on a distinguished road
Hi Ender,
You can use of ForAll loop and if statement for this purpose.
rapierrz is offline   Reply With Quote
Old   February 22, 2016, 22:08
invadoria's Avatar
Ender Demirel
Originally Posted by alexeym View Post
I used the following body in fvOptions to set the C in the cellSet named Inlet. But it gives zero value for the C when I run the code. I'm not sure that the code is correct..
scalarVariableC
type scalarExplicitSetValue;
active true;
timeStart 0;
duration 10;
selectionMode cellSet;
cellSet Inlet;
scalarExplicitSetValueCoeffs
volumeMode absolute;
injectionRate
C 100;
Old   February 23, 2016, 04:38
Alexey Matveichev
If you are using scalarTransportFoam, unfortunately it does not support setting values explicitly (since in fact it does not create matrix object for equation, just uses solve(...) function).
If you would like to use fvOptions with scalarTransportFoam, you need the following modification of the solver (instead of just solve call):
fvScalarMatrix TEqn
    fvm::ddt(T)
  + fvm::div(phi, T)
  - fvm::laplacian(DT, T)
    fvOptions(T)
fvOptions.constrain(TEqn);
TEqn.solve();
with this fvOptions description:
setTValue
   active           true;
       timeStart        0;
       duration         10;
       cellSet          inlet;
       injectionRate
           T 100;
it works fine.
Another way is to use forAll loop, as proposed by rapierrz, something like this:
word inletPatchName("inlet");
scalar TValue = 100;
const polyPatch& inlet = mesh.boundaryMesh()[inletPatchName];
forAll(inlet, idx)
    label cellI = inlet.faceCells()[idx];
    T.internalField()[cellI] = TValue;
before solve block could do the trick. Code above sets T value in the cells adjacent to inlet patch.
Old   February 23, 2016, 10:14
Smile
invadoria's Avatar
Ender Demirel
fvScalarMatrix TEqn
    fvm::ddt(T)
  + fvm::div(phi, T)
    fvOptions(T)
TEqn.solve();
setTValue
   active           true;
       timeStart        0;
       duration         10;
       cellSet          inlet;
       injectionRate
           T 100;
it work fine.
forAll(inlet, idx)
Hello Alexey;
I used the fvOptions description and it works fine. Thank you for your suggestions..
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 02:23
FATAL ERROR:Maximum number of iterations exceeded zqlhzx OpenFOAM Running, Solving & CFD 4 July 13, 2016 15:53
Best way to pass a scalar variable to a runtime selectionnable class? Yann OpenFOAM Programming & Development 0 October 22, 2014 08:53
Diverging solution in transonicMRFDyMFoam tsalter OpenFOAM Running, Solving & CFD 30 July 7, 2014 06:20
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
