New solver for two-phase flows with phase-change heat transfer
Like Tree17Likes
Old   June 19, 2016, 11:54
ali
abdoli is on a distinguished road
hi liquidspoon.
i am interested using your code in foam-extend-3.1. but i received the attached error. could you help me.
thanks a lot
abdoli is offline   Reply With Quote
Old   November 23, 2018, 10:25
fa
yamifm0f is on a distinguished road
Hello
I have downloded your solver and I am trying to use it with openFoam v6
I have errors
dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C:148:38: error: ‘const class Foam::dynamicKistlerAlphaContactAngleFvPatchScalar Field’ has no member named ‘dimensionedInternalField’; did you mean ‘patchInternalField’?
<< " of field " << this->dimensionedInternalField().name()
The code does not recognise dimensionedInternalField
I change it to patchInternalField and I have a new error now
dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C:148:59: error: ‘class Foam::tmp<Foam::Field<double> >’ has no member named ‘name’
<< " of field " << this->patchInternalField().name()
The code does not like name and objectpath
Can you advice?
yamifm0f is offline   Reply With Quote
Old   July 24, 2019, 18:48
Default installation problem with interThermalPhaseChangeFoam
  #23
FaRa
Fahmida is on a distinguished road
Hello everyone. I wanted Install this solver in windows 10 for linux subsystem with OpenFoam-v1906. But I am getting the following error. How can I fix this error? Thank you.
fahmida@DESKTOP-9VUVGL4:~/OpenFOAM/OpenFOAM-v1906/CFD-PC/interThermalPhaseFoam$ source Allwmake.sh
wmake libso incompressibleTwoPhaseThermalMixture
/home/fahmida/OpenFOAM/OpenFOAM-v1906/wmake/wmake: line 456: make: command not found
/home/fahmida/OpenFOAM/OpenFOAM-v1906/wmake/wmake: line 459: make: command not found
wmake error: file '/home/fahmida/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/CFD-PC/interThermalPhaseFoam/incompressibleTwoPhaseThermalMixture/sourceFiles' could not be created in /home/fahmida/OpenFOAM/OpenFOAM-v1906/CFD-PC/interThermalPhaseFoam/incompressibleTwoPhaseThermalMixture
wmake interThermalPhaseChangeFoam
wmake error: file '/home/fahmida/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/CFD-PC/interThermalPhaseFoam/interThermalPhaseChangeFoam/sourceFiles' could not be created in /home/fahmida/OpenFOAM/OpenFOAM-v1906/CFD-PC/interThermalPhaseFoam/interThermalPhaseChangeFoam
wmake libso DynamicKistlerContactAngle
wmake error: file '/home/fahmida/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/CFD-PC/interThermalPhaseFoam/Libraries/DynamicKistlerContactAngle/sourceFiles' could not be created in /home/fahmida/OpenFOAM/OpenFOAM-v1906/CFD-PC/interThermalPhaseFoam/Libraries/DynamicKistlerContactAngle
Fahmida is offline   Reply With Quote
Old   January 23, 2020, 10:17
Peng Xie
xiepengupc is on a distinguished road
Please modify the Allwmake.sh file:
delete libso in the "wmake libso incompressibleTwoPhaseThermalMixture"
that is change wmake libso incompressibleTwoPhaseThermalMixture
to wmake incompressibleTwoPhaseThermalMixture
For OpenFoam-v1906 or other new versions, Compile library no longer need libso in the script.
xiepengupc is offline   Reply With Quote
Old   January 23, 2020, 17:10
Peng Xie
delete libso in the Allwmake.sh script :
Old   January 23, 2020, 17:16
Peng Xie
Old   January 23, 2020, 17:49
FaRa
Thank you. I am gonna try this and get back to you.☺
Old   January 23, 2020, 18:28
Peng Xie
Originally Posted by yamifm0f View Post
Hello
I have errors
Can you advice?
Hi yamifm0f,
Have you solved the problem? I meet the same problem...
atulkjoy likes this.
Old   July 2, 2020, 05:15
Lasse Brams Vinther
Swagga5aur is on a distinguished road
I updated the interThermalPhaseFoam sovler to openFOAM v6 some time ago, but forgot to post it here.
The code is found here https://github.com/Swagga5aur/interThermalPhaseFoam, note that interfaceSigmaProperties have been added compared to the original solver due to changes between the openfoam versions. This library contains some removed parameters.
Let me know if there are any issues, I haven't had time to test the solver only compiled it without errors.
frantov likes this.
Swagga5aur is offline   Reply With Quote
Old   August 21, 2020, 10:27
M Naarendharan
Naaren is on a distinguished road
Hi Lasse Brams Vinther,
I am Naarendharan from India. I am currently working with solver interThermalPhaseChangeFoam for my study of nucleate boiling. I saw your post in the thread "New solver for two-phase flows with phase-change heat transfer". I tried downloading and compiling the solver updated by you.
I tried in 2 versions of OpenFOAM.
1. Windows subsystem for Linux -Ubuntu: 18.04 LTS; OpenFOAM version: v2006.
2. Dual Boot (In another system) - Ubuntu: 18.04 LTS; OpenFoam version: v6
I am attaching the screenshot of the errors. I would be very much grateful if you could help me with this error.
https://drive.google.com/drive/folde...yR?usp=sharing
Thanking you,
Yours Faithfully,
M Naarendharan,
Naaren is offline   Reply With Quote
Old   September 7, 2020, 03:29
Default Tutorial gives dimension errors?
  #31
Francisco T
frantov is on a distinguished road
Hi Swagga5aur. Thanks for the upgrade to OF6.
I downloaded and compiled your code. Seems to compile without errors.
I tried to run a tutorial from the repo (OF2.4 MadhuNabil/CFD/PC), Im getting a dimension error.
I noticed you mentioned, the interfaceSigmaProperties have been added. Can this be the issue?
What update does the tutorial need?
thanks for your time
Fran
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field alpha1
Reading field U
Reading field T
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting incompressible thermal transport model Fourier
Selecting turbulence model type laminar
Selecting laminar stress model Stokes
Selecting phase change model: InterfaceEquilibrium_SplitDilatation
--> FOAM FATAL ERROR:
Different dimensions for =
dimensions : [0 0 -1 0 0 0 0] = [0 3 -1 0 0 0 0]
frantov is offline   Reply With Quote
Old   September 8, 2020, 17:25
Lasse Brams Vinther
Hello Francisco,
I'm unable to get to the same point as you with the case, could you please verify that it works to the same point. The more you do the more I will have time to help with your actual issue.
I am able to run the Stefan case when removing the function call in controlDict and moving the blockMesh file from constant to system.
Old   September 10, 2020, 02:34
Default dimension errors?
  #33
Francisco T
Hi Lasse, thanks for your reply and thanks in advance for your time.
Im able to run Stefan case.
Im interested in the NucleateBoiling2D as Im interested in the kislter dynamic angle library.
By some reason Im unable to install swak4foam in OF6, but I have it running on OF7.
Therefore mesh generation is done in OF7.
Then I need I also update Axis bc in alpha, H, p_rgh, T, U, to symmetry instead of symmetryPlane
type symmetry; //symmetryPlane;
I guess this change is need because of the version update.
I can see the mesh and fields in paraview without error. Then,
when running interThermalPhaseChangeFoam I get the errow below:
Also, Im getting the same error on a 3D case (droplet impacting a surface case also attached)
Duplicate entry interfaceCompression in runtime selection table surfaceInterpolationScheme
#0 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam5error14safePrintStackERSo+ 0x49) [0x7fb6118070b9]
#1 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libinterfaceProperties.so(_ZN4Foam26surfaceInterpo lationSchemeIdE25addMeshConstructorToTableINS_9Phi SchemeIdNS_27interfaceCompressionLimiterEEEEC2ERKN S_4wordE+0x100) [0x7fb6143a4a40]
#2 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libinterfaceProperties.so(+0x2a460) [0x7fb614369460]
#3 /lib64/ld-linux-x86-64.so.2(+0x11b8a) [0x7fb61443ab8a]
#4 /lib64/ld-linux-x86-64.so.2(+0x11c91) [0x7fb61443ac91]
#5 /lib64/ld-linux-x86-64.so.2(+0x113a) [0x7fb61442a13a]
#1 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libinterfaceProperties.so(_ZN4Foam26surfaceInterpo lationSchemeIdE29addMeshFluxConstructorToTableINS_ 9PhiSchemeIdNS_27interfaceCompressionLimiterEEEEC2 ERKNS_4wordE+0x100) [0x7fb6143a50f0]
#2 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libinterfaceProperties.so(+0x2a488) [0x7fb614369488]
Duplicate entry interfaceCompression in runtime selection table limitedSurfaceInterpolationScheme
#1 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libinterfaceProperties.so(_ZN4Foam33limitedSurface InterpolationSchemeIdE25addMeshConstructorToTableI NS_9PhiSchemeIdNS_27interfaceCompressionLimiterEEE EC2ERKNS_4wordE+0x100) [0x7fb6143a57a0]
#2 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libinterfaceProperties.so(+0x2a4b0) [0x7fb6143694b0]
#1 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libinterfaceProperties.so(_ZN4Foam33limitedSurface InterpolationSchemeIdE29addMeshFluxConstructorToTa bleINS_9PhiSchemeIdNS_27interfaceCompressionLimite rEEEEC2ERKNS_4wordE+0x100) [0x7fb6143a5e50]
#2 /home/fran/OpenFOAM/OpenFOAM-6/platforms/linux64GccDPInt32Opt/lib/libinterfaceProperties.so(+0x2a4d8) [0x7fb6143694d8]
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
Build : 6
Exec : interKFoam
Date : Sep 10 2020
Time : 13:07:48
Host : "roverx230"
PID : 33522
I/O : uncollated
Case : /home/fran/OpenFOAM/fran-6/run/tutorials_thermal/NucleateBoiling2D
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Reading field p_rgh
Reading field U
Reading field T
From function bool Foam::dimensionSet:perator=(const Foam::dimensionSet&) const
in file dimensionSet/dimensionSet.C at line 171.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::dimensionSet:perator=(Foam::dimensionSet const&) const at ??:?
#3 Foam:imensionedField<double, Foam::volMesh>:perator=(Foam::tmp<Foam:imensio nedField<double, Foam::volMesh> > const&) in "/home/fran/OpenFOAM/fran-6/platforms/linux64GccDPInt32Opt/bin/interKFoam"
#4 ? in "/home/fran/OpenFOAM/fran-6/platforms/linux64GccDPInt32Opt/bin/interKFoam"
#5 ? in "/home/fran/OpenFOAM/fran-6/platforms/linux64GccDPInt32Opt/bin/interKFoam"
#6 ? in "/home/fran/OpenFOAM/fran-6/platforms/linux64GccDPInt32Opt/bin/interKFoam"
#7 ? in "/home/fran/OpenFOAM/fran-6/platforms/linux64GccDPInt32Opt/bin/interKFoam"
#8 ? in "/home/fran/OpenFOAM/fran-6/platforms/linux64GccDPInt32Opt/bin/interKFoam"
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? in "/home/fran/OpenFOAM/fran-6/platforms/linux64GccDPInt32Opt/bin/interKFoam"
Aborted (core dumped)
(base) fran@roverx230:~/OpenFOAM/fran-6/run/tutorials_thermal/NucleateBoiling2D$ .2(+0x11c91) [0x7fa33f629c91]
bash: syntax error near unexpected token `+0x11c91'
(base) fran@roverx230:~/OpenFOAM/fran-6/run/tutorials_thermal/NucleateBoiling2D$ #5/lib64/ld-linux-x86-64.so.2(+0x113a) [0x7fa33f61913a]
(base) fran@roverx230:~/OpenFOAM/fran-6/run/tutorials_thermal/NucleateBoiling2D$ Duplicate entry interfaceCompression in runtime selection table surfaceInterpolationSc
Old   June 10, 2021, 21:32
A. Min
alimea is on a distinguished road
Dear Lasse
I wanted to compil the code but I faced the following error:
correctPhi.H:37:41: error: ‘class Foam:impleControl’ has no member named ‘nNonOrthCorr’
37 | for (int nonOrth=0; nonOrth<=pimple.nNonOrthCorr(); nonOrth++)
correctPhi.H:47:31: error: ‘class Foam:impleControl’ has no member named ‘nNonOrthCorr’
47 | if (nonOrth == pimple.nNonOrthCorr())
In file included from interThermalPhaseChangeFoam.C:117:
pEqn.H:80:29: error: ‘class Foam::fvMesh’ has no member named ‘solver’; did you mean ‘Foam::dictionary Foam::solution::solvers_’? (not accessible from this context)
80 | p_rghEqn.solve(mesh.solver(p_rgh.select(pimple.fin alInnerIter())));
I checked the functions of pimpleControl class. There is no nNonOrthCorr().
Also if I deactivate the mentioned line, I will face the following error:
dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C: In member function ‘virtual void Foam::dynamicKistlerAlphaContactAngleFvPatchScalar Field::write(Foam::Ostream&) const’:
dynamicKistlerAlphaContactAngle/dynamicKistlerAlphaContactAngleFvPatchScalarField. C:242:27: error: no matching function for call to ‘writeEntry(const char [6], Foam::Ostream&)’
242 | writeEntry("value", os);
Do you know how to solve it?
Thanks
alimea is offline   Reply With Quote
Old   June 11, 2021, 02:18
Lasse Brams Vinther
Hello Alimea,
I just want to check first, you are using openfoam foundation version 6 right?
Old   June 11, 2021, 02:19
A. Min
Hello Alimea,
Hi Lasse
I'm using OpenFOAM-7
Old   June 12, 2021, 03:41
A. Min
Hello Alimea,
Hi Lasse
Excuse me, another question:
I just want to compile this solver to use the dynamic contact angle in another solver. Is it possible? If yes, can I compile it without the mentioned error?
Thanks
Old   September 8, 2021, 13:20
Lasse Brams Vinther
Hello Alimea,
to use the dynamic contact angle in another solver you would have to copy the solver, add the contact angle sub model and compile it as a new solver. Let me know if you need more assistance.
Old   December 10, 2021, 05:23
Pavithra is on a distinguished road
\\/ M anipulation |
Build : 6
Exec : interKFoam
Date : Sep 10 2020
Time : 13:07:48
Host : "roverx230"
PID : 33522
I/O : uncollated
nProcs : 1
Create time
Reading field p_rgh
Reading field U
Reading field T
FOAM aborting
Hello Francisco,
Have you solved this issue.? Could you please help me with it? I am facing the same problem, as you.
Thank You.
Pavithra is offline   Reply With Quote
Old   December 19, 2021, 18:38
Francisco T
Hi Pavithra
I have not worked on this issue for long time, I ll do it soon.
interfoam, phase change
Effective heat capacity - Phase change does not work!!! papteo CFX 8 October 31, 2013 05:15
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Which Code is Best for Two Phase, Heat Transfer earlc Main CFD Forum 0 September 23, 2005 20:26
compressible two phase flow in CFX4.4 youngan CFX 0 July 1, 2003 23:32
help needed about phase change Yanhu Guo Main CFD Forum 4 January 23, 2001 23:16
