April 13, 2016, 04:03 |
modification of pisoFoam
CFD_Lovers
Rep Power: 11 |
hi friends!
i want to add in concentration fields (S) and temperature(T) in to pisoFoam and i also i want to define a new formula for calculation of rho that is function of both S,T that is named Mille and Poisson (1981) equation of density. so i want to define this in pisoFoam.c and i compile it . and another changing is to a modification in momentum equation. so i did these to pisofoam.c and also i introduced S , T to creatField.H . in pisoFoam.c: rho==1000; rho==(rho/1000*(999.842594+6.793952e-2*T-(9.095290e-3*pow(T,2))+ (1.001685e-4*pow(T,3))-(1.120083e-6*pow(T,4))+(6.536336e-9*pow(T,5))+ S*(8.24493e-1-4.0899e-3*T+(7.6438e-5*pow(T,2))-(8.2467e-7*pow(T,3))+ (5.3875e-9*pow(T,4)))+(pow(S,1.5))*(-5.72466e-3+1.0227e-4*T-1.6546e-6*pow(T,2))+S*(4.8314e-4))); and in momentum equation: fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) + turbulence->divDevReff(U) -g*(rho-1000)/1000 ); UEqn.relax(); fvScalarMatrix SEqn ( fvm::ddt(rho, S) + fvm::div(rhophi, S) - fvm::laplacian(kappaEff, S) ); SEqn.relax(); SEqn.solve(); fvScalarMatrix TEqn ( fvm::ddt(rho, T) + fvm::div(rhophi, T) - fvm::laplacian(kappaEff, T) ); TEqn.relax(); TEqn.solve(); so when i want to compile this, i face with some errors: my_pisoFoam.C:65:2: error: ‘rho’ was not declared in this scope my_pisoFoam.C:76:16: error: ‘g’ was not declared in this scope my_pisoFoam.C:91:26: error: ‘rhophi’ was not declared in this scope my_pisoFoam.C:92:32: error: ‘kappaEff’ was not declared in this scope i should say that i changed the name of modified solver to my_pisoFoam. i know that in creatField.H of pisoFoam there is now any definition of "transport properties" and for exapmle kappaEff is one of constants that i introduced in transport properties directory like others that are in this directoru by defaults. i hope to my friends in FOAM can understand my question well!!! all the bests thank u all |
April 14, 2016, 00:41 |
Hesam
Rep Power: 11 |
Hi sina,
Please attach your solver. |
April 14, 2016, 14:04 |
CFD_Lovers
Rep Power: 11 |
hi friend!
i attached my modified solver to this reply any help is appreciated. thank u |
April 15, 2016, 01:45 |
#4 | |
Hesam
Rep Power: 11 |
You must define every variable that use in your code in createField or in .C file. And you should call gravitationalAcceleration.H in your headers for g. |
April 15, 2016, 13:44 |
CFD_Lovers
Rep Power: 11 |
Hi rapierrz!
i added #include "readGravitationalAcceleration.H" to fix problem of "g" and i added "Reading transportProperties\n" to fix problem of "kappaEff" and i added : surfaceScalarField rhoPhi ( IOobject ( "rho*phi", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), linearInterpolate(rho) * phi ); to fix "rhophi" problem . i copied that rhophi from creatField.H of inetrFoam solver so i compiled the solver again and the only error masege that i faced is : make: *** [Make/linux64GccDPOpt/my_pisoFoam.o] Error 1 and as u saw the solver i defined "S" and "T" fields and it is conventional to reading fields at first like reading field P reading field U ,... so i'm expecting to see reading field S and T but it doesn't occur unfortunately ! i attached it again thanks for your guidance |
April 15, 2016, 13:59 |
attachment of previous reply!
CFD_Lovers
Rep Power: 11 |
i missed to attach solver in previous reply
April 15, 2016, 14:02 |
CFD_Lovers
Rep Power: 11 |
i think there is a problem to attachment ! i'm trying my_pisoFoam (copy).tar.gz
April 15, 2016, 15:53 |
#8 | |
Hesam
Rep Power: 11 |
Please,put your full error massage. |
April 16, 2016, 02:05 |
#9 |
CFD_Lovers
Rep Power: 11 |
Hi rapierrz,
that error message that i put here is the last line of compiling! and before it there is some warning messages that I've seen in other compilation before. in this case before the last line that it contains the error some lines are : /opt/openfoam221/src/OpenFOAM/lnInclude/VectorSpaceI.H:634:13: note: template<class Form, class Cmpt, int nCmpt> bool Foam:perator==(const Foam::VectorSpace<Form, Cmpt, nCmpt>&, const Foam::VectorSpace<Form, Cmpt, nCmpt>&) /opt/openfoam221/src/finiteVolume/lnInclude/readPISOControls.H:3:15: warning: unused variable ‘nOuterCorr’ [-Wunused-variable] /opt/openfoam221/src/finiteVolume/lnInclude/readPISOControls.H:15:16: warning: unused variable ‘transonic’ [-Wunused-variable] make: *** [Make/linux64GccDPOpt/my_pisoFoam.o] Error 1 thanks for your attentions |
April 16, 2016, 02:45 |
#10 |
Hesam
Rep Power: 11 |
Hi sina,
In your code,there are a lots of errors and ill defined parameters. before you start to write your own code,you should start with simple case such as add temperature to icoFoam: https://openfoamwiki.net/index.php/H...ure_to_icoFoam with this manner you can add S and T fields to your code. also,you should read about units and mathematical operators in openfoam. good luck. |
April 16, 2016, 04:11 |
#11 |
CFD_Lovers
Rep Power: 11 |
Hi friend
actually i read that one (how to add temperature field to icoFoam) i'm learnig FOAM. bur as u read the code before! was it full of ill defined parameters and so on ?!! thanks a lot for your attentions |
Differences in solution method for pisoFoam and buoyantBoussinesqPisoFoam | mchurchf | OpenFOAM | 7 | August 6, 2023 09:12 |
How can I get stedaystate solution from pisoFoam? | mykkujinu2201 | OpenFOAM Running, Solving & CFD | 1 | December 8, 2015 07:37 |
Porosity model not found for pisoFoam; works fine for simpleFoam | aerogt3 | OpenFOAM | 2 | September 13, 2014 16:39 |
pisoFoam, pimpleFoam - Fluent user's questions | RodriguezFatz | OpenFOAM Running, Solving & CFD | 0 | September 4, 2013 04:26 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
