How to go through every element of a field?
Like Tree2Likes
  • 1 Post By akidess
  • 1 Post By Democritus
Old   April 15, 2016, 05:32
Default How to go through every element of a field?
Democritus's Avatar
Xiaoqiu HE
Democritus is on a distinguished road
Hello Dear Foamers~!
In my project i want to define a complex source field. For example, I want solve the equation:
volScalarField p;
volScalarField sourceField;
solve( fvm::laplacian( p ) == sourceField )
Furthermore, the source filed is a complex space function, for example, such as
f(x, y, z) = sin(x) * cos(y) * z
Here is my though about this problem:
1. one field of every cell center's position must be obtained, that can be achieved by:
volVectorField centerPostions = mesh.C();
2. there must be a method in order to read through every element of the field. such as:
for(i = first_element_index, i <= last_element_index, i++)
     sourceField.element(i) = sin( centerPosition.element(i).x() ) * .....
I was blocked in the second step, dear foamers, is there a method can accomplish that?
I am open for every advices!
Thanks very much!
Democritus is offline   Reply With Quote
Old   April 15, 2016, 06:52
Default One possible way?
Democritus's Avatar
Xiaoqiu HE
As every field can be seen as UList<Type>, so it comes to me that if method inside the class template can help.
Old   April 15, 2016, 07:29
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
You are looking "forAll" (search the forum for this keyword).
Democritus likes this.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   April 16, 2016, 02:40
Default Problem almost solved!
Democritus's Avatar
Xiaoqiu HE
Thank you very much for your response!
After searching and studying the threads of the forum with key word "forAll". I have got the basic understanding of the macro "forAll". What's more, I have developed my own "manual" method in order to scan a field:
    Foam::vector * i;
    Foam::label j = 0;
    volVectorField position = mesh.C();
    Info << "\n the first method of scanning the field " << endl;
    for ( i = position.begin(); i <= position.end(); i++) {
      Info << "\n the cell " << j << "'s position is " << position[j] << endl;
      j++;
      if (j == 5) {
        break;
    Info<< "\n the second method of scanning the field " << endl;
    j = 0;
    forAll( position, elmtID ){
      Info << "\n the cell " << elmtID << "'s position is " << position[elmtID] << endl;
      j++;
      if (j == 5) {
        break;
and the result is quite well:
the cell 0's position is (1.25e-05 0.000125 0.0001)
the cell 1's position is (3.75e-05 0.000125 0.0001)
the cell 2's position is (6.25e-05 0.000125 0.0001)
the cell 3's position is (8.75e-05 0.000125 0.0001)
the cell 4's position is (0.0001125 0.000125 0.0001)
akidess likes this.
programming, user code
funkySetBoundaryFields - Manipulation of existing field jhertel OpenFOAM Pre-Processing 16 May 18, 2020 06:32
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 18:44
Problems creating a volScalarField with expressionField function-object zfaraday OpenFOAM Running, Solving & CFD 2 January 12, 2015 07:49
New BoundaryCondition: how to modify a single component of a field? look86 OpenFOAM Programming & Development 4 August 28, 2012 16:48
Demagnetization field jan0385 ANSYS 0 April 12, 2012 09:09
