max command hangs when using scotch decomposition
Old   July 2, 2020, 03:55
Default max command hangs when using scotch decomposition
ssa
ssa_cfd is on a distinguished road
Hi everyone,
In my solver, there is a command as follows
Info << "max/min Massendefekt: " << max(massendefektFeld).value() << "     " << min(massendefektFeld).value() << endl;
There is no problem, when I run in serial or parallel with simple decomposition.
But when I use scotch decomposition, the solver hangs exactly at this point.
I tried to comment out this line and then it runs smoothly.
Does anyone know why?
Thanks,
ssa.
ssa_cfd is offline   Reply With Quote
Old   July 2, 2020, 10:59
clapointe is on a distinguished road
If you want to find the max for a parallel case, try using gMax instead of max. There are loads of examples in the code, e.g. https://github.com/OpenFOAM/OpenFOAM...m/setRDeltaT.H.
Caelan
clapointe is offline   Reply With Quote
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
Converging Diverging Nozzle with dbnsTurbFoam Saleh Abuhanieh OpenFOAM Running, Solving & CFD 4 December 13, 2019 10:26
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 13:48
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
