Thermal conductivity as function of temperature
Like Tree4Likes
  • 1 Post By magazoni
  • 3 Post By mkraposhin
Old   October 10, 2012, 06:32
Default Thermal conductivity as function of temperature
magazoni
magazoni is on a distinguished road
Hi everyone,
I'm trying to make a test with the solver laplacianFoam making the thermal conductivity as function of temperature. I'm doing something like that:
fvScalarMatrix Teqn
fvm::ddt(rho, T)
- fvm::laplacian(k_T(T)/Cp, T)
Teqn.solve();
My idea is create a function to calculate the thermal conductivity:
dimensionedScalar k_T(volScalarField T)
dimensionedScalar k1
"k1",
dimensionSet(1,1,-3,-2,0,0,0),
-0.0691734413
dimensionedScalar k2
"k2",
dimensionSet(1,1,-3,-1,0,0,0),
421.0792245378
volScalarField k;
k=k1*T+k2;
return k;
But it's not working. How can I do it using a function?
Thanks,
Best regards,
Felipe Magazoni
Kummi likes this.
magazoni is offline   Reply With Quote
Old   October 10, 2012, 07:42
Chrisi1984 is on a distinguished road
Hi Felipe,
the following code should give you an idea how to do it:
for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++)
fvScalarMatrix tEqn
-fvm::laplacian(K, T)
tEqn.relax();
eqnResidual = tEqn.solve().initialResidual();
maxResidual = max(eqnResidual, maxResidual);
Info<< "Min/max T:" << min(T).value() << ' '
<< max(T).value() << endl;
forAll(solidRegions[i].cellZones(), zoneI)
const cellZone& cz = solidRegions[i].cellZones()[zoneI];
const labelList& cells = cz;
if (cz.name() == "s-oc")
forAll(cells, iCells)
const label cellId = cells[iCells];
const scalar& cellT = T[cellId];
cp[cellId] = 380.68 + cellT * (0.35536 - 0.00012713 * cellT);
K[cellId] = 9.6995954 + cellT * (0.017429246 - 2.0551036e-06 * cellT);
rho[cellId] = 7920;
It is an example for a steady solver, but it should not be that difficult to modify it for your time depending equation.
Don't forget to define your variables in the "createFields" file.
Kind regards
Chrisi
Chrisi1984 is offline   Reply With Quote
Old   December 31, 2012, 09:19
Romain
nakor is on a distinguished road
hello Chrisi,
I am looking to implement something a bit similar, I would like to have a value 'a' for my thermal conductivity if the temperature is under a certain value, and a value 'b' for my thermal conductivity if the temperature is above the value.
Something like,
if (cellT<273.15)
K[cellId] = 10;
else
K[cellId] = 100;
rho[cellId] = 7920;
is that possible ? I never used those kind of thermal dependent constant in my code before.
Thanks,
nakor is offline   Reply With Quote
Old   January 5, 2013, 10:54
Hallo Nakor,
at the minute for me it seems that your code should work.
Kind regards,
Chrisi
Old   January 6, 2013, 11:52
mkraposhin's Avatar
Matvey Kraposhin
mkraposhin is on a distinguished road
I can hint a bit more elegant solution:
dimensionedScalar k1 (dict.lookup("k1"));
dimensionedScalar k2 (dict.lookup("k2"));
volScalarField k = k1*T + k2;
volScalarField DT = k / Cp1;
fvScalarMatrix Teqn
fvm::ddt(rho, T)
- fvm::laplacian(DT, T)
Teqn.solve();
cfdsolver1, amolrajan and mikulo like this.
mkraposhin is offline   Reply With Quote
Old   May 19, 2016, 18:25
Scram_1 is on a distinguished road
Hey,
I have modified the icoFoam solver to solve the energy equation by following the steps detailed in https://openfoamwiki.net/index.php/H...ure_to_icoFoam
Now, I want to make the thermal diffusivity (DT) temperature dependent.
Can someone tell me how to go about doing this? Where should I make the changes?
Thanks!!
Ram
Scram_1 is offline   Reply With Quote
function, laplacianfoam, property, temperature
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
THERMAL CONDUCTIVITY FOR SOLID DOMAIN -BOUYANCY CARL CFX 1 June 9, 2006 16:44
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 10:18
