Implementation of a coupled boundary condition crashes
Old   August 3, 2016, 07:30
Default Implementation of a coupled boundary condition crashes
koala is on a distinguished road
Hey,
First my case:
I have a multi region mesh which consists of, let's say, the regions A, B and C where different equations are solved. And I want to couple the regions A and B because there are similar equations solved. I'm using a multi physics solver like chtMultiRegionSimpleFoam.
I want to modify an already existing boundary condition ("compressible::turbulentTemperatureCoupledBaffleM ixed") from the chtMultiRegionSimpleFoam solver. When I test my modified BC the solver crashes with the message:
--> FOAM FATAL ERROR:
request for polyMesh B from objectRegistry TESTCASE failed
available objects of type polyMesh are
1
region0
It seems that he can't find the polyMesh B which is created during the meshing procedure. I also used the search function and found similar problems but either the author found a solution and didn't post it or the problem was ignored because it was posted in an other thread.
Thanks in advance for your help!
Edit: the error message occurs when the coupling boundary condition for region A is called.
koala is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Accessing multiple boundary patches from a custom boundary condition file ripudaman OpenFOAM Programming & Development 0 October 22, 2014 18:34
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Dirchilet boundary condition implementation in FVM Aero.Sam Main CFD Forum 0 May 17, 2012 05:45
regarding coupled boundary condition VAIBHAV Main CFD Forum 0 November 9, 2007 19:40
