How to modify const volScalarField& T = thermo.T(); |
August 7, 2016, 05:01 |
Zhiheng Wang
Rep Power: 10 |
In my boundary condition Temperature T changes with gradient. how can I modify if T is defined as "const volScalarField& T = thermo.T();" in creatField.H. I want to correct T at boundary with some function. please provide the solution. |
August 7, 2016, 18:55 |
Mahdi Hosseinali
Rep Power: 18 |
Are you trying to do this along with a standard solver? Or you are developing your own solver?
Sorry but your problem is not clear. If you want to update the boundary condition based on its gradient, there are many boundary conditions available that you may choose depending on your problem such as fixedGradient and mixed |
August 8, 2016, 03:07 |
#3 | |
Zhiheng Wang
Rep Power: 10 |
dT/dy = rho*Uy*LatentHeat/kappa; I know how to take sngrad in account to calculate dT/dy but my boundary temperature is not changing due to const volScalarField , it gives error |
August 8, 2016, 10:42 |
#4 | |
Mahdi Hosseinali
Rep Power: 18 |
You can use
If your only going to change the boundary condition then why are you developing a solver? And if you are developing a whole new solution that involves solver and boundary just develop them separate. I'm still not clear if the formula you mentioned is going to be used only on boundary or the whole domain, but I guess it can either be done with already existing conditions or developed separately from the solver. |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 04:28 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
Wall bounded values and streamlines | Ruli | OpenFOAM Post-Processing | 5 | February 2, 2014 16:45 |
[snappyHexMesh] Error in SnappyHexMesh | gooya_kabir | OpenFOAM Meshing & Mesh Conversion | 2 | October 23, 2013 04:41 |
LiftDrag coefficient in LES | fabian_korn | OpenFOAM Post-Processing | 1 | September 22, 2008 02:34 |
