Setting boundary values for a volScalarField
Old   August 25, 2016, 08:07
Default Setting boundary values for a volScalarField
Bloerb will become famous soon enough
I want to monitor some field values and write them out.
I created a volScalarField for that purpose
    Info<< "Reading field myField\n" << endl;
    volScalarField myField
        IOobject
            "myField",
            runTime.timeName(),
            mesh,
            IOobject::READ_IF_PRESENT,
            IOobject::AUTO_WRITE
        fieldA*fieldB
And have a line inside my solver loop to set the values
 myField = fieldA*fieldB
I also want to set the boundary values of this field. The boundary should have the normal gradients of both fields multiplied with each other. I think i have to use myField.boundaryField() but how do I set it to equal fvc::snGrad(field1) & snGrad(field2) ?
I have no clue as to how to do this.
Bloerb is offline   Reply With Quote
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Warning 097- AB Siemens 6 November 15, 2004 05:41
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
