Run Time Selection table pointer error
Old   November 18, 2016, 06:31
Default Using Run Time Selection : table pointer error at run time
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Hi
I attempt to write a custom solid body motion solver. The external force management is massively inspired from "sixDoFRigidBodyMotion" (many thanks to the author), and uses the Run Time Selection mechanism.
The problem is that the RTS table pointer is not found and throw an error at run time.
Here's the skeleton of my code and the run error message.
I've been struggling with that bug for days.
I probably miss something big, too big to be seen ?
Dear RTS specialists, I would appreciate your help so much
Jean-Michel
/* solver.C
    Info<< "Create bodyMotion" << nl << endl;
    bodyMotion motion(mesh, bodyFluidDict);
/* bodyMotion.C
// * * * * * * * * * * Constructors * * * * * * * * *
Foam::bodyMotion::bodyMotion
    fvMesh& mesh,
    const dictionary& bodyFluidDict
    // Add all the external actions
    createAllExternActions(bodyFluidDict);
// * * * * * * * * * * Public * * * * * * * * * * *
void Foam::bodyMotion::createAllExternActions
    if (bodyFluidDict.found("externalActions"))
        const dictionary& actionsDict = bodyFluidDict.subDict("externalActions");
        label iAction = 0;
        externActionsPtrList_.setSize(actionsDict.size());
        // Loop for reading each sub-sub-dictionary of actionsDict
        forAllConstIter(IDLList<entry>, actionsDict, iter)
            if (iter().isDict())
                    iAction++,
                    bodyExternActions::New
                        iter().keyword(),
                        iter().dict()
        externActionsPtrList_.setSize(iAction);
/* bodyExternActionsNew.C
 * Copy from sixDoFRigidBodyMotionRestraint::New()
Foam::autoPtr<Foam::bodyExternActions> Foam::bodyExternActions::New
    const word& customName,
    const dictionary& actionDict
    const word actionType
        actionDict.lookup("externalAction")
    if (!dictionaryConstructorTablePtr_)
        FatalErrorIn
            "bodyExternActions::New(customName, actionDict)"
        << exit(FatalError);
///////////////////// FATAL ERROR /////////////////////////////////////////////
/*  bodyExternActions.C
 *  Copy from sixDoFRigidBodyMotionRestraint.C
#include "bodyExternActions.H"
namespace Foam
    defineTypeNameAndDebug(bodyExternActions, 0);
    defineRunTimeSelectionTable(bodyExternActions, dictionary);
/*  bodyExternActions.H:
 *  Copy from sixDoFRigidBodyMotionRestraint.H
// Forward declaration of classes
class bodyMotion;
class bodyExternActions
public:
    //- Runtime type information
    TypeName("bodyExternActions");
    // Declare run-time constructor selection table
        declareRunTimeSelectionTable
            autoPtr,
            bodyExternActions,
            dictionary,
            (const word& name, const dictionary& actionsDict),
            (name, actionsDict)
    // Constructors
        //- Construct from the actionsDict dictionary
        bodyExternActions
            const word& name,
        //- Construct and return a clone
        virtual autoPtr<bodyExternActions> clone() const = 0;
    // Selectors
        //- Select constructed from the actionsDict dictionary
        static autoPtr<bodyExternActions> New
            const word& name,
/* bodySpring.C
 * Copy from linearSpring.C
#include "bodySpring.H"
#include "addToRunTimeSelectionTable.H"
#include "bodyMotion.H"
// * * * * * * * * * * * * * * Static Data Members * * * * * * * * * * * * * //
namespace Foam
namespace bodyExternActions
    defineTypeNameAndDebug(bodySpring, 0);
        bodyExternActions,
        bodySpring,
        dictionary
/* bodyFluidDict
externalActions
    spring1
        externalAction      bodySpring;
        anchor              ( 0.0   -0.0     0.0);
        refAttachmentPt     (-0.0    0.0     0.0);
        stiffness           1000;
        damping             1000;
        restLength          0;
The run error message :
Create bodyMotion
> Creates new bodyExternActions:
spring1
    anchor          ( 0 -0 0 );
    refAttachmentPt ( -0 0 0 );
    stiffness       1000;
    damping         1000;
    restLength      0;
#0  Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/printStack.C:219
#1  Foam::sigSegv::sigHandler(int) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OSspecific/POSIX/signals/sigSegv.C:56
#2  ? in "/lib64/libc.so.6"
#3  Foam::HashTable<Foam::autoPtr<Foam::bodyExternActions> (*)(Foam::word const&, Foam::dictionary const&), Foam::word, Foam::string::hash>::find(Foam::word const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/HashTable.C:143
#4  Foam::bodyExternActions::New(Foam::word const&, Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/bodyFluid/bodyMotion/bodyExternActionsNew.C:39
#5  Foam::bodyMotion::createAllExternActions(Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/bodyFluid/bodyMotion/bodyMotion.C:258 (discriminator 1)
#6  Foam::bodyMotion::bodyMotion(Foam::fvMesh&, Foam::dictionary const&) at ~/OpenFOAM/OpenFOAM-2.4.0/src/bodyFluid/bodyMotion/bodyMotion.C:73
#7  ? at ~/OpenFOAM/OpenFOAM-2.4.0/applications/solvers/multiphase/bodyWaveFoam/bodyWaveFoam.C:47
#8  __libc_start_main in "/lib64/libc.so.6"
#9  ? at /home/abuild/rpmbuild/BUILD/glibc-2.18/csu/../sysdeps/x86_64/start.S:125
jmf is offline   Reply With Quote
runtime selection
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 02:36
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
