November 25, 2016, 06:14 |
write fields to file in parallel
Luca
Rep Power: 15 |
Dear all,
I am implementing a new function object (for post-processing purposes) to write the cell center values and the selected field values of the internal mesh and the boundary patches to a file. It works in serial (part of the code for single processor only) but I am facing problems for the parallel case. Here attached you find the code of the templated function for writing the data to the file. It accepts as argument the name of the field in the function object dictionary and the name of the file to be written. My main concern is when the "slave" processors pass the data to the master in order to write them on the file. Indeed, while the cells (mesh.C().internalField()) and face center (mesh.boundaryMesh()[patchi].faceCentres()) data are correctly stored as "pointField", the same is not correct for the field data. "pointField" is a vector type and it is therefore not correct to store a generic field value that can be a scalar, a vector or a tensor. My question is then which object type should I use to store the fields passed from the slave to the master instead of pointField? How should I modify that part of the code? Thank you in advance for your help. Luca Code:
#include "writeFieldsToFile.H" #include "volFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // template<class Type> void Foam::writeFieldsToFile::writeData ( const word& fieldName, const fileName& outputFile ) { typedef GeometricField<Type, fvPatchField, volMesh> fieldType; if (obr_.foundObject<fieldType>(fieldName)) { const fieldType& field = obr_.lookupObject<fieldType>(fieldName); const fvMesh& mesh = field.mesh(); Info<< nl << "Writing components of " << field.name() << " at cellCentres" << " to " << outputFile << endl; Info<< " Number of cells written " << field.size() << endl; OFstream os(outputFile); label nCells = mesh.C().size(); label nFields = field.size(); reduce(nCells, sumOp<label>()); Info << "Number of global cells: " << nCells << endl; reduce(nFields, sumOp<label>()); Info << "Number of global fields: " << nFields << endl; // slaves send data to master, master writes data to file if (Pstream::parRun()) { if (Pstream::myProcNo() != Pstream::masterNo()) { OPstream toMaster(Pstream::blocking, Pstream::masterNo()); toMaster << mesh.C().internalField() << field.internalField(); } else // master part { forAll(mesh.C(), cellI) { os<< mesh.C()[cellI].component(0) << tab << mesh.C()[cellI].component(1) << tab << mesh.C()[cellI].component(2) << tab << field.internalField()[cellI] << endl; } pointField bufferCellCenters; pointField bufferFieldValues; for (int slave=Pstream::firstSlave(); slave <= Pstream::lastSlave(); slave++) { IPstream fromSlave(Pstream::blocking, slave); fromSlave >> bufferCellCenters >> bufferFieldValues; Info<< "BufferCellCenters size: " << bufferCellCenters.size() << endl; forAll(bufferCellCenters, cellI) { os<< bufferCellCenters[cellI].component(0) << tab << bufferCellCenters[cellI].component(1) << tab << bufferCellCenters[cellI].component(2) << tab << bufferFieldValues[cellI] << endl; } } } // write boundary data to file const fvPatchList& patches = mesh.boundary(); forAll(patches, patchi) { const polyPatch& cPatch = mesh.boundaryMesh()[patchi]; label nFaces = cPatch.size(); reduce(nFaces, sumOp<label>()); const vectorField& faceCentres = mesh.boundaryMesh()[patchi].faceCentres(); label nFields = faceCentres.size(); reduce(nFields, sumOp<label>()); forAll(field.boundaryField()[patchi],facei) { Info<< nl << field.boundaryField()[patchi][facei] << endl; } if (Pstream::myProcNo() != Pstream::masterNo()) { OPstream toMaster(Pstream::blocking, Pstream::masterNo()); toMaster << faceCentres << field.boundaryField()[patchi]; } else // master part { forAll(faceCentres, faceI) { // get coordinate for face center const vector& c = faceCentres[faceI]; os<< c[0] << tab << c[1] << tab << c[2] << tab << field.boundaryField()[patchi][faceI] << endl; } pointField bufferFaceCenters; pointField bufferFieldValues; for (int slave=Pstream::firstSlave(); slave <= Pstream::lastSlave(); slave++) { IPstream fromSlave(Pstream::blocking, slave); fromSlave >> bufferFaceCenters >> bufferFieldValues; Info<< "BufferFaceCenters size: " << bufferFaceCenters.size() << endl; forAll(bufferFaceCenters, faceI) { // get coordinate for face center const vector& c = bufferFaceCenters[faceI]; os<< c[0] << tab << c[1] << tab << c[2] << tab << bufferFieldValues[faceI] << endl; } } } } } else // single processor only { forAll(mesh.C(), cellI) { os<< mesh.C()[cellI].component(0) << tab << mesh.C()[cellI].component(1) << tab << mesh.C()[cellI].component(2) << tab << field.internalField()[cellI] << endl; } const fvPatchList& patches = mesh.boundary(); forAll(patches, patchi) { const fvPatchVectorField& faceCentres = mesh.C().boundaryField()[patchi]; forAll(faceCentres, faceI) { // get coordinate for face center const vector& c = faceCentres[faceI]; os<< c[0] << tab << c[1] << tab << c[2] << tab << field.boundaryField()[patchi][faceI] << endl; } } } } } |
December 11, 2016, 11:43 |
Sergei
Rep Power: 21 |
December 11, 2016, 12:33 |
Luca
Rep Power: 15 |
Dear Zeppo,
thanks a lot for your reply. I already tried that and actually it compiles. When you run the case you get the following error because the first keyword it finds is the type of the boundary field and not an integer number or a parentheses. Do you have an idea how to fix it? Thanks, Luca Writing components of U at cellCentres to "/home/marluc/OpenFOAM/marluc-2.4.0/run/tutorials/incompressible/pimpleFoam/channel395/processor0/../postProcessing/writeFieldsToFile/0.2/cellCenterData_U" Number of cells written 60000 [0] [0] [0] --> FOAM FATAL IO ERROR: [0] incorrect first token, expected <int> or '(', found on line 0 the word 'type' [0] [0] file: IOstream at line 0. [0] [0] From function operator>>(Istream&, List<T>&) [0] in file /home/openfoam/OpenFOAM/OpenFOAM-2.4.0/src/OpenFOAM/lnInclude/ListIO.C at line 149. [0] FOAM parallel run exiting [0] EDIT: Dear Sergei, I think my answer to your post was not clear so I try to formulate it better here. Here you find the new version of the code: Code:
#include "writeFieldsToFile.H" #include "volFields.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // template<class Type> void Foam::writeFieldsToFile::writeData ( const word& fieldName, const fileName& outputFile ) { typedef GeometricField<Type, fvPatchField, volMesh> fieldType; if (obr_.foundObject<fieldType>(fieldName)) { const fieldType& field = obr_.lookupObject<fieldType>(fieldName); const fvMesh& mesh = field.mesh(); const DimensionedField<Type,volMesh>& iField = field.dimensionedInternalField(); OFstream os(outputFile); label nCells = mesh.C().size(); label nFields = field.size(); reduce(nCells, sumOp<label>()); reduce(nFields, sumOp<label>()); // slaves send data to master, master writes data to file if (Pstream::parRun()) { if (Pstream::myProcNo() != Pstream::masterNo()) { OPstream toMaster(Pstream::blocking, Pstream::masterNo()); toMaster << mesh.C().internalField() << field.internalField(); } else // master part { Info<< nl << "Writing components of " << field.name() << " at cellCentres" << " to " << outputFile << endl; Info<< " Number of cells written " << nCells << endl; forAll(mesh.C(), cellI) { os<< mesh.C()[cellI].component(0) << tab << mesh.C()[cellI].component(1) << tab << mesh.C()[cellI].component(2) << tab << field.internalField()[cellI] << endl; } vectorField bufferCellCenters; Field<Type> bufferFieldValues; for (int slave=Pstream::firstSlave(); slave <= Pstream::lastSlave(); slave++) { IPstream fromSlave(Pstream::blocking, slave); fromSlave >> bufferCellCenters >> bufferFieldValues; forAll(bufferCellCenters, cellI) { os<< bufferCellCenters[cellI].component(0) << tab << bufferCellCenters[cellI].component(1) << tab << bufferCellCenters[cellI].component(2) << tab << bufferFieldValues[cellI] << endl; } } } // write boundary data to file const fvPatchList& patches = mesh.boundary(); forAll(patches, patchi) { const polyPatch& cPatch = mesh.boundaryMesh()[patchi]; const vectorField& faceCentres = cPatch.faceCentres(); if (Pstream::myProcNo() != Pstream::masterNo()) { OPstream toMaster(Pstream::blocking, Pstream::masterNo()); toMaster << faceCentres << field.boundaryField()[patchi]; } else // master part { forAll(faceCentres, faceI) { // get coordinate for face center const vector& c = faceCentres[faceI]; os<< c[0] << tab << c[1] << tab << c[2] << tab << field.boundaryField()[patchi][faceI] << endl; } pointField bufferFaceCenters; Field<Type> bufferFieldValues; for (int slave=Pstream::firstSlave(); slave <= Pstream::lastSlave(); slave++) { IPstream fromSlave(Pstream::blocking, slave); fromSlave >> bufferFaceCenters >> bufferFieldValues; forAll(bufferFaceCenters, faceI) { // get coordinate for face center const vector& c = bufferFaceCenters[faceI]; os<< c[0] << tab << c[1] << tab << c[2] << tab << bufferFieldValues[faceI] << endl; } } } } } else // single processor only { forAll(mesh.C(), cellI) { os<< mesh.C()[cellI].component(0) << tab << mesh.C()[cellI].component(1) << tab << mesh.C()[cellI].component(2) << tab << field.internalField()[cellI] << endl; } const fvPatchList& patches = mesh.boundary(); forAll(patches, patchi) { const fvPatchVectorField& faceCentres = mesh.C().boundaryField()[patchi]; forAll(faceCentres, faceI) { // get coordinate for face center const vector& c = faceCentres[faceI]; os<< c[0] << tab << c[1] << tab << c[2] << tab << field.boundaryField()[patchi][faceI] << endl; } } } } } I hope the problem is now a little bit clearer. I would be greatful to anyone who can help me in fixing it. Thank you in advance, Luca Last edited by marluc; December 12, 2016 at 15:36. Reason: Additional information added |
December 17, 2016, 15:27 |
Sergei
Rep Power: 21 |
So the error comes from the second part of the code where you process boundary values? Slave processes send field.boundaryField()[patchi] which is of fvPatchField<T> type and a master process expects to receive Field<Type>. The data should be consistent, try
Field<Type> bufferFieldValues; Code:
fvPatchField<T> bufferFieldValues; |
December 17, 2016, 16:50 |
Luca
Rep Power: 15 |
Dear Sergei,
thanks a lot for your answer. Actually I already tried this solution but without success. Here the first lines of the error message I get during compilation when using fvPatchField<Type> instead of Field<Type>. If you have an idea how to fix it I would be very grateful. Thanks, Luca Code:
In file included from writeFieldsToFile/writeFieldsToFile.H:240:0, from writeFieldsToFile/writeFieldsToFile.C:26: writeFieldsToFile/writeFieldsToFileTemplates.C: In instantiation of ‘void Foam::writeFieldsToFile::writeData(const Foam::word&, const Foam::fileName&) [with Type = double]’: writeFieldsToFile/writeFieldsToFile.C:204:59: required from here writeFieldsToFile/writeFieldsToFileTemplates.C:220:40: error: no matching function for call to ‘Foam::fvPatchField<double>::fvPatchField()’ fvPatchField<Type> bufferFieldValues; ^ writeFieldsToFile/writeFieldsToFileTemplates.C:220:40: note: candidates are: In file included from /opt/openfoam240/src/finiteVolume/lnInclude/fvPatchField.H:588:0, from /opt/openfoam240/src/finiteVolume/lnInclude/volFields.H:40, from writeFieldsToFile/writeFieldsToFileTemplates.C:27, from writeFieldsToFile/writeFieldsToFile.H:240, from writeFieldsToFile/writeFieldsToFile.C:26: /opt/openfoam240/src/finiteVolume/lnInclude/fvPatchField.C:170:1: note: Foam::fvPatchField<Type>::fvPatchField(const Foam::fvPatchField<Type>&, const Foam::DimensionedField<Type, Foam::volMesh>&) [with Type = double] Foam::fvPatchField<Type>::fvPatchField ^ |
December 18, 2016, 07:21 |
Sergei
Rep Power: 21 |
The error
writeFieldsToFile/writeFieldsToFileTemplates.C:220:40: error: no matching function for call to ‘Foam::fvPatchField<double>::fvPatchField()’ Also, fromSlave >> bufferFieldValues wouldn't work either even if we had an object of fvPatchField<T> because there is no Istream& operator>>(Istream&, fvPatchField<T>&) defined. When you write fromSlave >> bufferFieldValues the function template<class T> Istream& operator>>(Istream&, List<T>&) is invoked. This is possible since fvPatchField<T> is derived from List<T>. And it is reasonable that operator>>(Istream&, List<T>&) can only take a perfect list (check this: http://cpp.openfoam.org/v4/a07944_source.html) At the same time it is perfectly ok to write toMaster << field.boundaryField()[patchi] as there's a specific operator to stream your fvPatchField<T> out: Code:
template<class Type> Foam::Ostream& Foam::operator<<(Ostream& os, const fvPatchField<Type>& ptf) { ptf.write(os); os.check("Ostream& operator<<(Ostream&, const fvPatchField<Type>&"); return os; } Possible solutions: 1. If you are not interested in patch type information you can recast fvPatchField to List: Code:
toMaster << field.boundaryField()[patchi]; -> toMaster << static_cast<const List<Type>&>( field.boundaryField()[patchi]); Code:
List<Type> bufferFieldValues; ... fromSlave >> bufferFieldValues; |
December 18, 2016, 08:57 |
Solved
Luca
Rep Power: 15 |
Dear Sergei,
thanks a lot for your detailed explanation. Actually I tried to recast fvPatchField but not in the way you did. And your way is correct! Now it works. I really learned something important and useful from you. thanks again for the time spent on my question. Best regards, Luca Last edited by marluc; December 18, 2016 at 08:59. Reason: added SOLVED to title |
December 18, 2016, 09:53 |
Sergei
Rep Power: 21 |
Luca, you are welcome.
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
