November 26, 2016, 11:22 |
Insert Dimensioned Salar
Rep Power: 10 |
Hello to all,
i'm creating a new adjoint solver and i have to implement new boundary conditions. i made all but i still have to add a dimensioned scalar constant to make the boundary condition correct, dimensionally talking. i added these lines to the adjointOutletVelocityFvPatchVectorField.C Code:
scalar Ke = readScalar(db().lookupObject<IOdictionary>("transportProperties").lookup("Ke")); Here my transportProperties file Code:
transportModel Newtonian; nu nu [0 2 -1 0 0 0 0] 1.02e-06; Ke Ke [0 7 -5 0 0 0 0] 1; lambda lambda [0 -2 1 0 0 0 0] 1e5; alphaMax alphaMax [0 0 -1 0 0 0 0] 200.0; Code:
wrong token type - expected Scalar, found on line 22 the word 'Ke' file: /home/roby/Scrivania/HAGAGA/constant/transportProperties.Ke at line 22. From function operator>>(Istream&, Scalar&) in file lnInclude/Scalar.C at line 93. Any idea? Thanks for help |
November 28, 2016, 04:15 |
#3 | |
Rep Power: 10 |
thank you for your reply. I corrected my code and that line doesn't give me error anymore. However another very strange error has appeared. Here part of my code Code:
// GETTING NU const incompressible::RASModel& ras = db().lookupObject<incompressible::RASModel>("RASProperties"); scalarField nuw = ras.nuEff()().boundaryField()[patch().index()]; // DISTANCE^(-1) const scalarField& deltainv = patch().deltaCoeffs(); // nu / h const scalarField& nd = - nuw * deltainv; // NORMAL VECTOR vectorField n = patch().nf(); // TANGENT VECTOR vectorField r = patch().Cf() - vector(10,11,12); // SCALAR NORMAL VELOCITY COMPONENT scalarField Un = Up & patch().nf(); // DIMENSIONED CORRECTION COEFFICIENT const dimensioned<double> Ke = readScalar(db().lookupObject<IOdictionary>("transportProperties").lookup("Ke")); // PATCH-ADIACENT TANGENT ADJOINT VELOCITY (VECTOR) vectorField Uac = Uap.patchInternalField(); vectorField Uac_n = ( Uac & patch().nf() ) * patch().nf(); vectorField Uac_t = Uac - Uac_n; // TANGENT VELOCITY COMPONENT (VECTOR) vectorField U_n = ( Up & patch().nf() ) * patch().nf(); vectorField U_t = Up - U_n; vectorField :: operator = ( phiap*patch().Sf()/sqr(patch().magSf()) + (1/(Un + nd)) * (nd * Uac_t + Ke * (n ^ r) / (pow(mag(r^U_t),3) + SMALL)) ); Code:
/home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricFieldFunctionsM.C:119:55: note: template<template<class> class PatchField, class GeoMesh> Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, PatchField, GeoMesh> > Foam::operator*(const Foam::GeometricField<Foam::Vector<double>, PatchField, GeoMesh>&) tmp<GeometricField<ReturnType, PatchField, GeoMesh> > operator Op \ ^ /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricTensorField.C:60:1: note: in expansion of macro ‘UNARY_OPERATOR’ UNARY_OPERATOR(tensor, vector, *, hdual, transform) ^ /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricFieldFunctionsM.C:119:55: note: template argument deduction/substitution failed: tmp<GeometricField<ReturnType, PatchField, GeoMesh> > operator Op \ ^ /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricTensorField.C:60:1: note: in expansion of macro ‘UNARY_OPERATOR’ UNARY_OPERATOR(tensor, vector, *, hdual, transform) ^ adjointOutletVelocity/adjointOutletVelocityFvPatchVectorField.C:143:58: note: ‘const Foam::dimensioned<double>’ is not derived from ‘const Foam::GeometricField<Foam::Vector<double>, PatchField, GeoMesh>’ * (nd * Uac_t + Ke * (n ^ r) / (pow(mag(r^U_t),3) + SMALL)) ^ In file included from /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricTensorField.C:30:0, from /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricTensorField.H:88, from /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricFields.H:36, from /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/finiteVolume/lnInclude/volFields.H:37, from adjointOutletVelocity/adjointOutletVelocityFvPatchVectorField.C:27: /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricFieldFunctionsM.C:147:55: note: template<template<class> class PatchField, class GeoMesh> Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, PatchField, GeoMesh> > Foam::operator*(const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, PatchField, GeoMesh> >&) tmp<GeometricField<ReturnType, PatchField, GeoMesh> > operator Op \ ^ /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricTensorField.C:60:1: note: in expansion of macro ‘UNARY_OPERATOR’ UNARY_OPERATOR(tensor, vector, *, hdual, transform) ^ /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricFieldFunctionsM.C:147:55: note: template argument deduction/substitution failed: tmp<GeometricField<ReturnType, PatchField, GeoMesh> > operator Op \ ^ /home/roby/OpenFOAM/OpenFOAM-2.3.0/src/OpenFOAM/lnInclude/GeometricTensorField.C:60:1: note: in expansion of macro ‘UNARY_OPERATOR’ UNARY_OPERATOR(tensor, vector, *, hdual, transform) ^ adjointOutletVelocity/adjointOutletVelocityFvPatchVectorField.C:143:58: note: ‘const Foam::dimensioned<double>’ is not derived from ‘const Foam::tmp<Foam::GeometricField<Foam::Vector<double>, PatchField, GeoMesh> >’ * (nd * Uac_t + Ke * (n ^ r) / (pow(mag(r^U_t),3) + SMALL)) |
November 28, 2016, 07:51 |
Ben Jankauskas
Rep Power: 12 |
I'm not sure whether this is correct advice. But you are using operator ^ in multiple areas. As I understand you are trying to raise to the power, eg. n ^ r . But my guess is that this operator is not defined, and you should use function: Code:
double pow(double x, double y) x - base y - power Cheers, Ben |
November 28, 2016, 09:11 |
#5 | |
Rep Power: 10 |
Hi rhythm, thank you for your reply. It's strange because when i don't include the Ke term, the solvers compile correctly but when i run my case the solvers stops. I firstly thought it was up to the fact the formula wasn't dimensionally correct, so i try to insert the Ke term to make it balanced (but i'm not sure this is the problem). In the image the boudary condition i have to implement. I took it from a report so it should be correct. n represents the normal vector of the outlet, while r the distance vector between the outlet center and the point considered. Best Regards, Roberto |
November 28, 2016, 10:05 |
// GETTING NU const incompressible::RASModel& ras = db().lookupObject<incompressible::RASModel>("RASProperties"); scalarField nuw = ras.nuEff()().boundaryField()[patch().index()]; // DISTANCE^(-1) const scalarField& deltainv = patch().deltaCoeffs(); // nu / h const scalarField& nd = - nuw * deltainv; // NORMAL VECTOR vectorField n = patch().nf(); // TANGENT VECTOR vectorField r = patch().Cf() - vector(10,11,12); // SCALAR NORMAL VELOCITY COMPONENT scalarField Un = Up & patch().nf(); // DIMENSIONED CORRECTION COEFFICIENT const dimensioned<double> Ke = readScalar(db().lookupObject<IOdictionary>("transportProperties").lookup("Ke")); // PATCH-ADIACENT TANGENT ADJOINT VELOCITY (VECTOR) vectorField Uac = Uap.patchInternalField(); vectorField Uac_n = ( Uac & patch().nf() ) * patch().nf(); vectorField Uac_t = Uac - Uac_n; // TANGENT VELOCITY COMPONENT (VECTOR) vectorField U_n = ( Up & patch().nf() ) * patch().nf(); vectorField U_t = Up - U_n; vectorField :: operator = ( phiap*patch().Sf()/sqr(patch().magSf()) + (1/(Un + nd)) * (nd * Uac_t + Ke * pow(n, r) / (pow(mag(pow(r,U_t),3) + SMALL)) ); |
November 28, 2016, 10:29 |
#7 | |
Ben Jankauskas
Rep Power: 12 |
Hi FlyBob91,
Ah.. My apologies I wasn't sure that the hat represented a cross product between vectorFields. (P.S.: shereez234 sorry about me causing confusion in the thread. As FlyBob91 wants to perform cross product operation between n and r then his use of 'hat' operator is correct, and it is not a power operator) Quote:
As I am not entirely sure what is the issue, would you mind sending the code, for me to play around with and see if I can fix the issue? Cheers, Ben |
November 28, 2016, 10:30 |
#8 | |
Rep Power: 10 |
I don't understand why you wrote Code:
pow(n, r) Code:
pow(r,U_t),3 I thought the cross product should be written with the operator ^ Best Regards, Roberto |
November 28, 2016, 10:42 |
#9 | |
Rep Power: 10 |
P.S. i'm working on OpenFoam 2.3.0 |
November 28, 2016, 11:10 |
#10 |
That is correct. I am sorry I thought you were trying to use the power. Many Apologies
November 29, 2016, 09:28 |
#11 |
Ben Jankauskas
Rep Power: 12 |
With very minor change I got it to compile. Try running it and see if it works. There is a comment in the code explaining the change and why I believe it should be the correct way of doing it. Cheers, Ben |
December 1, 2016, 09:39 |
#12 | |
Rep Power: 10 |
I have no words for thanking you and sorry for my late answer but i have been really busy in these days. Your comment in the boundary condition file makes me think Code:
do not carry dimension values with them So, trying with the old but good method of trial and error, i found the problematic therm was this one Code:
const scalarField& nd = - nuw * deltainv; Code:
phiap*patch().Sf()/sqr(patch().magSf()) + (1/(Un - nuw * deltainv)) * (-nuw * deltainv * Uac_t + 2 * (n ^ r) / (pow(mag(r^U_t),3) + SMALL)) ); However i have a last question in the following therm Code:
// TANGENT VECTOR vectorField r = patch().Cf() - vector(10,11,12); HTML Code:
vector(10,11,12) Thank you another time for you help, you played a key role for the solution. Best Regards, Roberto |
December 2, 2016, 06:56 |
#13 |
Ben Jankauskas
Rep Power: 12 |
Regarding the dimensions of the boundary conditions. I have had a discussion with my colleagues last year and it seems that in OpenFOAM the implementation is currently such that the boundary condition files (such as your adjointOutletPressureFvPatchScalarField) do not carry dimensions. So far I haven't seen any of the boundary conditions that are written differently. We presumed that later when the solver is running the Field just picks numerical values from the boundary condition and uses it's own set dimension values. My guess is that this is done to avoid the need to have different boundary conditions for each type of field with different dimensions, or it might just be a less involved way to write it, but that is just a guess. Anyway, when you are writing a boundary condition file, you only need to work with primitives like scalarFields, vectorFields, doubles, floats, etc. which you've been doing for the most part (apart from that Ke parameter). Regarding the question about vector value, I'm afraid I don't have an answer, though I'm pretty sure there should be a function in the code that does that. Cheers, Ben |
Grabbing value of a dimensioned quantity / Problem creating a dimensioned tensor | ThomasV | OpenFOAM | 5 | February 18, 2019 11:05 |
Insert Points in CFD-Post | Supersonic | ANSYS | 3 | August 26, 2016 01:45 |
Division of dimensioned scalars | Joachim | OpenFOAM | 5 | August 8, 2013 01:53 |
dimensioned volScalarField | lions85 | OpenFOAM | 1 | November 12, 2009 02:41 |
3D Insert modelling in Mold Flow | Dan Rößler | Main CFD Forum | 0 | December 20, 2005 06:37 |
