February 20, 2017, 07:41 |
wo does negSumDiag() work?
toboto
Rep Power: 9 |
Dear all,
I am totally confused regarding how the diagonal coefficient in OpenFOAM is calculated. I know that this is done using the negSumDiag() function as follows: Code:
void Foam::lduMatrix::negSumDiag() 51 { 52 const scalarField& Lower = const_cast<const lduMatrix&>(*this).lower(); 53 const scalarField& Upper = const_cast<const lduMatrix&>(*this).upper(); 54 scalarField& Diag = diag(); 55 56 const labelUList& l = lduAddr().lowerAddr(); 57 const labelUList& u = lduAddr().upperAddr(); 58 59 for (label face=0; face<l.size(); face++) 60 { 61 Diag[l[face]] -= Lower[face]; 62 Diag[u[face]] -= Upper[face]; 63 } 64 } Is this valid for any case, i.e. even if the matrix isn't symmetric? Can you please provide a reference on the relation between diagonal and off-diagonal coefficients for different flow cases? Best regards. |
RP_Set_Integer does not work in parallel | 86lolo | Fluent UDF and Scheme Programming | 2 | July 3, 2014 11:37 |
Does CX_Interpret_String work in parallel? | 86lolo | Fluent UDF and Scheme Programming | 2 | June 30, 2014 04:36 |
Companies that lease software & hardware for cloud-based work? | Catthan | ANSYS | 0 | June 18, 2014 10:53 |
Why do the Plant library cases don't work? | Alumna | Phoenics | 6 | June 22, 2004 12:08 |
why my In-Form doesn't work? | green | Phoenics | 2 | May 27, 2004 21:03 |
