firctional viscosity
Old   March 24, 2017, 06:04
Default firctional viscosity
Arne
Arne87 is on a distinguished road
Dear Foamers,
I am trying to implement the grannular theory into the multiphaseEulerFoam solver of openFOAM. This implementation has been done often in a Euler-Euler Framework.
(See for example: Cornelissen(2007) CFD modelling of a liquid–solid fluidized bed or different works of Berend van Wachem)
The implementation is almost finished it produces reasonable results. However, I have some problems with the term for the frictional viscosity. In most cases the approach of Schaeffer is used:
\mu_{s,fric} =\frac{p_s*sin \phi}{2*\sqrt{I_{2D}}}
here p_s is the solid pressure, \phi is the internal friction angle ( in my case 30 degree) and I_{2D} is referred to as the "second invariant of the deviatoric stress tensor". Cornelissen et. al. state that the I_{2D} is non dimensional. The dimension of p_s is
\frac{kg }{s^2 \cdot m}.
As this isn't a viscosity this can't be right.
Following the description of the term "second invariant of the deviatoric stress tensor" I_{2D} should have the dimension:
\frac{kg^2 }{m^2 \cdot s^4}.
Anyways using this I again don't end up with the right dimension.
If anybody has experience with this term or can identify my mistake I would be glad to get some input.
Best
Arne
Arne87 is offline   Reply With Quote
Old   May 22, 2018, 09:56
Default internal frictional angle
mohit dhoriya
mohit68 is on a distinguished road
can you tell me how did you decided the value of internal frictional angle?
mohit68 is offline   Reply With Quote
Dynamic viscosity and Kinematic viscosity asal FLUENT 7 September 3, 2019 01:25
Problem with divergence TDK FLUENT 13 December 14, 2018 06:00
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? JuPa CFX 7 September 9, 2013 07:45
Too low temperature at combustor outlet romekr FLUENT 2 February 6, 2012 10:02
kinematic viscosity at diff temperatures,pressures Mecobio Main CFD Forum 0 November 7, 2005 12:55
