April 6, 2017, 05:18 |
Modifying laplacianFoam
Lilian Chabannes
Rep Power: 9 |
Hello everyone,
[Editing this post when some things are solved] I'm totally new to OpenFOAM and i'm trying to modify laplacianFoam to calculate a parameter "alpha" () (cure degree for a chemical reaction). I'm trying to do simple things to begin but i'm lost . So basically, I want to calculte this first (it calculates an induction time, because the reaction doesn't start immediatly) (induction time) And because the reaction is non-isotherm And when this sum equals 1 (induction is over), the reaction begins : with or directly : (cure rate of the reaction) Everything is constant except T (temperature) and t (time) - t0 [s] : time constant - T0 [K] : Temperature constant - k0 [s-1] : a frequency factor - Ea [J/mol] = [kg m2 s-2 mol-1] : activation energy - n [-] : reaction degree Thanks to alexeym, everything is solved, here are the lines of codes added to the solver : Code:
volScalarField ti(t0*Foam::exp(T0/T)); //calculation of isothermal induction time sumti += runTime.deltaT()/ti; //calculation to know when we reach the induction time volScalarField xi(pos(sumti - 1)); //xi = 0 before induction reached for each cells, and 1 and it is reached forAll(xi, i) { // tsum[i] > 1.0 for the first time if (xi.v()[i] == 1.0 and tinduction.v()[i] == 0.0) //if induction time is over AND tinduction has not been modified yet { tinduction[i] = runTime.value(); //assign the value of the induction in the volScalarField tinduction } } volScalarField k(k0*Foam::exp(-Ea/R/T)); //declaration and calculation of k, to help in the calcul of alpha Info<< "\nCalculating cure rate distribution\n" << endl; // For a cell, if induction time is not over, alpha = 0 (due to xi) // if induction time is over, alpha is calculated alpha = xi*k*Foam::pow(runTime.value()-tinduction, n)/(k*Foam::pow(runTime.value()-tinduction, n)+1/k1); //the term k1 in the end is here to avoid dimensional problems, it doesn't change the result Last edited by Lookid; April 11, 2017 at 09:48. |
April 7, 2017, 05:00 |
Lilian Chabannes
Rep Power: 9 |
I'm trying to implement da/dt, but I have a problem with pow function.
Add this on laplacianFoam solve ( fvm::ddt(a) - n*Foam:ow(k0*Foam::exp(-Ea/(R*T)),1/n)*Foam:ow(a,(n-1)/n)*Foam:ow((1-a),(n+1)/n) ); It compiles well, but when I run it I have this error : [a[0 0 -1 0 0 0 0] ] - [(((n*pow((k0*exp((-Ea|(R*T)))),(1|n)))*pow(a,((n-1)|n)))*pow((1-a),((n+1)|n)))[0 0 -0.465116 0 0 0 0] ] From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam:imensionedField<Type, Foam::volMesh>&, const char*) [with Type = double] in file /home/lilian/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1292. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam:imensionedField<double, Foam::volMesh> const&, char const*) at ??:? #3 ? at ??:? #4 ? at ??:? #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? at ??:? Abandon (core dumped) This term pow((k0*exp((-Ea|(R*T)))),(1|n))) should be of dimension [0 0 -1 0 0 0 0]. k0 is like this, Ea/RT is dimensionless, and n is also dimensionless. But on the error : [0 0 -0.465116 0 0 0 0], 1/n = 0.465116, so it multiplies the value of n with the dimension of k0, I don't get it. If I put 1 on the pow functions, then it works. |
April 7, 2017, 05:21 |
Foam::pow(a,(n-1)/n)*Foam::pow((1-a),(n+1)/n) Why do you want to solve equation instead of direct calculation of a? |
April 7, 2017, 05:26 |
Lilian Chabannes
Rep Power: 9 |
Because in the initial formula, I have a term "t^n", and I don't know how to implement t.
Plus, I may add a source term in the energy equation later, which is proportional to da/dt. Thanks for the tip, but a problem comes from before, when I try to solve this : fvm::ddt(a) - n*pow((k0*exp((-Ea|(R*T)))),(1|n))) I already have the dimension problem |
April 7, 2017, 05:39 |
As I said, your dimension problem comes from the fact, that you have used just 1 instead of dimensioned 1. So 1 - a is in fact dimensionless instead of 1/s (since instead of complaining modern OpenFOAM will construct dimless dimensionedScalar from 1 and then during - operation it will again take dimensions of the first operand).
Use something like: Code:
const dimensionedScalar ONE("1", a.dimensions(), 1.0); ... Foam::pow(a, (n - 1)/n)*Foam::pow((ONE - a), (n + 1)/n) ... |
April 7, 2017, 06:20 |
Lilian Chabannes
Rep Power: 9 |
Thanks again but it's still not working.
I tried stupid thing like declare "one" in transportproperties, and still the same. Even when I try without the "1", like this : Code:
solve ( fvm::ddt(a) - n*Foam::pow(k0*Foam::exp(-Ea/(R*T)),n) ); Code:
--> FOAM FATAL ERROR: [a[0 0 -1 0 0 0 0] ] - [(n*pow((k0*exp((-Ea|(R*T)))),n))[0 0 -2.15 0 0 0 0] ] From function void Foam::checkMethod(const Foam::fvMatrix<Type>&, const Foam::DimensionedField<Type, Foam::volMesh>&, const char*) [with Type = double] in file /home/lilian/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/fvMatrix.C at line 1292. |
April 7, 2017, 08:00 |
April 7, 2017, 09:38 |
Lilian Chabannes
Rep Power: 9 |
Yes of course, sorry for this .
I put another coefficient in front of it of dimension 1/n and value 1, but that's not how it should work. With this both sides have the same dimensions but the result is nonsense, 'a' should vary from 0 to 1 (1 = reaction over), but it stays 0. Maybe there's a way to say "solve this just with values and don't look at the dimensions". I modified the first post to explain my whole problem clearly. Last edited by Lookid; April 7, 2017 at 11:03. |
April 10, 2017, 10:07 |
Lilian Chabannes
Rep Power: 9 |
Thanks to alexeym, i'm doing some steps in my problem ! I edited the first post again to show what has been done.
the calculation of alpha is made, and alpha = 0 when induction is not over, which is good. But the calculation of alpha starts at the current time and it has to start at t=0, which means implement t = current time - induction time for each nodes but I didn't success in it yet. A volScalarField t_induction is created, and I'm trying to store the time value when injection is over for each nodes with something like Code:
if (xi=1) { t_induction = runTime.deltaT()... Do you have any clues ? |
April 11, 2017, 09:49 |
Lilian Chabannes
Rep Power: 9 |
Problem solved , the lines of code added are in the first post.
Multi-region problem using laplacianFoam | zfaraday | OpenFOAM Pre-Processing | 9 | March 19, 2023 06:20 |
Heat source using fvOptions in laplacianFoam | osha | OpenFOAM Programming & Development | 4 | October 27, 2020 04:28 |
Add solar radiation to laplacianFoam | aar_out | OpenFOAM Programming & Development | 2 | April 30, 2017 15:12 |
laplacianFoam run-time error | industrial0503 | OpenFOAM Running, Solving & CFD | 2 | June 6, 2012 14:16 |
Serious error in calculating gradT (laplacianFoam) | doubtsincfd | OpenFOAM Bugs | 1 | December 30, 2011 02:56 |
