Any possibility to calculate grad*grad implicitly?
Like Tree4Likes
  • 1 Post By xuegy
  • 1 Post By Tobi
  • 1 Post By Tobi
  • 1 Post By xuegy
Old   May 16, 2017, 13:23
Default Any possibility to calculate grad*grad implicitly?
xuegy is on a distinguished road
Hello all,
I have a mass transport equation with term
where c is unknown concentration to be solved and T is known temperature from previous equation.
I transformed the above term into
And since term grad(T) is dominating, I want to solve grad(C) implicitly. However there's only fvc::grad(C) to use.
So is there any possibility to solve this term implicitly?
Thanks.
Kummi likes this.
xuegy is offline   Reply With Quote
Old   May 16, 2017, 18:22
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
No, the gradient can only be calculated with the last stored values. I never heard that people calculate the gradient implicitly. Now I am wondering, if it would be possible in general. Well. In FOAM it is not possible. See page 35: http://foam.sourceforge.net/docs/Gui...mmersGuide.pdf
Kummi likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   May 16, 2017, 19:43
Actually I don't need an implicit gradient. All I need is an implicit inner product of two gradients, which is a scalar.
Or, can I discretize the original term directly?
Old   May 17, 2017, 02:19
Tobi's Avatar
Tobias Holzmann
Hi, the First Term is a laplacian which can be treated implicitly.
Sent from my HTC One mini using CFD Online Forum mobile app
Keep foaming,
Tobias Holzmann
Old   May 17, 2017, 09:08
Tobi's Avatar
Tobias Holzmann
I was talking to my colleague Chris about that and I am sorry to get the message wrong.
You are solving for c which I was not aware yesterday. So what you could try is:
a) Solve TEqn.
b) Build you gradT = fvc::grad(T) field
c) Solve your equation and treat your divergence term implicitly like:
\nabla \bullet (c \nabla T) = \nabla \bullet (\nabla T c) = \mathrm{div}(\nabla T c)
which would be:
fvm::div(gradT, c)
Keep foaming,
Tobias Holzmann
Old   May 17, 2017, 09:27
No, this won't work.
It says:
cannot convert ‘gradT’ (type ‘Foam::volVectorField {aka Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh>}’) to type ‘const surfaceScalarField& {aka const Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&}’
That's why I split the divergence term.
Old   May 17, 2017, 09:46
Tobi's Avatar
Tobias Holzmann
Ah, of course. I am sorry again. So you have to interpolate the gradient to the surface first. Thus you have to do the following:
a) create a new surfaceScalarField
b) Interpolate the gradT to the surfaces
c) use this field in the divergence term
Like:
volScalarField gradT = fvc::grad(T);
surfaceScalarField gradTf = fvc::interpolate(gradT) & mesh.Sf();
fvm::div(gradTf, c)
Keep foaming,
Tobias Holzmann
Old   May 17, 2017, 10:45
Yeah I can compile it. I can't wait to see the result of a testing case.
So is it something like a heat flux without thermal conductivity?
Old   May 18, 2017, 07:40
Tobi's Avatar
Tobias Holzmann
Yes, the physical meaning of the divergence is the flux which is going in and out of an volume element. I have no idea how you got to that term because it would mean that the concentration (of some species?), is transported by the temperature gradient (like a temperature flux). Thus, the concentration is moving to the highest temperature (if I have the sign correct - or vice versa). However, normally only the velocity can transport a quantity by fluxes. But maybe there is some physical meaning behind your term that I don't know. In the general conservation equations, I never saw a term like that.
But nice to hear, that it is working.
openfoam_aero likes this.
Keep foaming,
Tobias Holzmann
Old   May 18, 2017, 08:25
It's called thermophoresis. Particles can be driven by temperature gradient.
Calculate CF Odusseas Tecplot 3 August 28, 2020 14:16
calculate friction factor & nusselt number soheil1991 FLUENT 3 March 11, 2017 09:30
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 02:57
The terms that should be treated implicitly in LES ben Main CFD Forum 3 January 28, 2005 03:32
How to calculate density of solid phase zhou Main CFD Forum 0 December 17, 1999 19:06
