No such file or directory: #include <features.h>
Old   December 29, 2020, 16:59
Default No such file or directory: #include <features.h>
ulugbey is on a distinguished road
I want to write a simple code in OpenFoam
// A hello world program in C++
#include<iostream>
using namespace std;
int main()
                cout << "Hello World!";
                return 0;
when I try to compile this code using
g++ hello_world.cpp
It throws an error
In file included from /root/OpenFOAM/ThirdParty-v1712/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/c++config.h:507:0,
from /root/OpenFOAM/ThirdParty-v1712/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/iostream:38,
from hello_world.cpp:2:
/root/OpenFOAM/ThirdParty-v1712/platforms/linux64/gcc-6.3.0/include/c++/6.3.0/x86_64-pc-linux-gnu/bits/os_defines.h:39:22: fatal error: features.h: No such file or directory
compilation terminated.
Do you have an idea why I get this error?
Best regards.
ulugbey is offline   Reply With Quote
Old   December 30, 2020, 16:04
Tobermory will become famous soon enough
This is a little odd. Did you list the WHOLE of your code?
#include<iostream>
int main()
                return 0;
or do you have other lines in your hello_world.cpp? The compiler/linker is complaining that it can't include header file features.h, since it doesn't know where it is, but I don't see a
line in your code ... unless you only shared part of the code, in which case the problem is in the bit you didn't share!
Tobermory is offline   Reply With Quote
Old   December 30, 2020, 17:02
I shared the whole code. There is not another part.
Old   January 1, 2021, 06:26
Ok - that IS wierd, but a quick google search shows that it's a fairly common problem that's not associated with OpenFOAM - there's something wrong/incomplete with your g++ installation, see e.g.:
https://stackoverflow.com/questions/...ow-do-i-get-it
Try checking/reinstalling your g++ installation. Good luck.
Old   January 1, 2021, 09:11
Thanks,
Your suggestion helped to solve the problem.
I implemented
sudo apt-get install g++-multilib
It works now!
Old   January 1, 2021, 12:37
Great job - well done!
c++, coding, openfoam 1712
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
polynomial BC srv537 OpenFOAM Pre-Processing 4 December 3, 2016 09:07
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
OpenFoam install script Error during paraFoam installation SePe OpenFOAM Installation 10 June 19, 2010 15:15
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
