Adding non-static function to Foam::myPCG::solve?
Old   August 25, 2017, 13:01
Default Adding non-static function to Foam::myPCG::solve?
Klaus
klausb will become famous soon enough
I get the following compile error:
myPCG.C: In member function ‘virtual Foam::solverPerformance Foam::myPCG::solve(Foam::scalarField&, const scalarField&, Foam::direction) const’:myPCG.C:171:33: error: invalid use of non-static member function ldu2ublas(matrix, ublas_matrix);
    scalarField& psi,
    const scalarField& source,
    const direction cmpt
) const
    // --- Setup class containing solver performance data
    solverPerformance solverPerf
        lduMatrix::preconditioner::getName(controlDict_) + typeName,
        fieldName_
    uint n = psi.size();
    boost::numeric::ublas::compressed_matrix<scalar> ublas_matrix(n,n);
    ldu2ublas(matrix, ublas_matrix);  // error: invalid use of non-static member function
ldu2ublas() is used to store the OpenFoam matrix which has LDU format in CSR format in a boost ublas compressed_matrix.
Where/How must I introduce the function so it can be used in the solve section in PCG.C?
Klaus
klausb is offline   Reply With Quote
conjugateHeatFoam + interFoam farhagim OpenFOAM Programming & Development 15 July 19, 2016 07:55
Adding a new member function to SingleStepCombustion tatu OpenFOAM Programming & Development 1 January 8, 2014 23:54
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
