November 27, 2017, 03:51 |
declaration of variable number of classes
Elham
Rep Power: 16 |
I am going to modify multiphaseInterFoam and make n classes in a library which n is the number of species. So n is not a constant number and depends on the model. How can I declare it in the library? Regards, Elham |
December 3, 2017, 12:31 |
Re: declaration of variable number of classes
Charles
Rep Power: 9 |
Assuming your class is "species", can you do something similar as below?
species *mySpecies mySpecies = new species[n] |
December 3, 2017, 20:01 |
Elham
Rep Power: 16 |
thanks for the suggestion. I will try.
Elham |
decomposePar no field transfert | Jeanp | OpenFOAM Pre-Processing | 3 | June 18, 2022 12:01 |
decomposePar -allRegions | stru | OpenFOAM Pre-Processing | 2 | August 25, 2015 03:58 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
Stable boundaries | marcoymarc | CFX | 33 | March 13, 2013 06:39 |
