reactingEulerFoam
Old   October 27, 2015, 04:20
Default reactingEulerFoam
Mattia de\' Michieli Vitturi
demichie is on a distinguished road
Hi all,
I am trying to understand how mass transfer is implemented in the new reactingEulerFoam in OpenFOAM-dev and I've seend tht the contribution to the momentum trafner between the phases associated with the mass transfer is in HeatAndMassTransferPhaseSystem.C:
*eqns[pair.phase1().name()] += dmdt21*U2 - fvm::Sp(dmdt21, U1);
*eqns[pair.phase2().name()] -= dmdt12*U1 - fvm::Sp(dmdt12, U2);
where
const volScalarField dmdt(this->dmdt(pair));
const volScalarField dmdt21(posPart(dmdt));
const volScalarField dmdt12(negPart(dmdt));
I think it should be:
*eqns[pair.phase1().name()] += dmdt21*U2 - fvm::Sp(dmdt12, U1);
*eqns[pair.phase2().name()] -= dmdt12*U1 - fvm::Sp(dmdt21, U2);
because the speed associated to a mass transfer from phase 1 to phase 2 is U1.
In addition, this formulation does not take into account that a positive mass transfer could be the result of transfers in the two directions (condensation of one component and evaporation of another one). These two contributions should be kept separated when considering the momentum and heat transfer. Considering only the positive and negative part of dmdt does not allow to do that.
Should I report this as a bug in the bug tracker?
Mattia
demichie is offline   Reply With Quote
Old   October 27, 2015, 04:40
I am digging more into the solver and I have noticed that when the face momentum equations are used (pUf instead of pU) the correct formulation is used:
U1Eqn =
fvm::div(alphaRhoPhi1, U1) - fvm::Sp(fvc::div(alphaRhoPhi1), U1)
+ fvm::Sp(dmdt12, U1) + dmdt21*U2
So, the problem is only in the centered formulation for the momentum equation. This could be an explanation of the difference in the convergence for the two formulations.
Still regarding the mass transfer terms in the equations, I have not found it in the alpha equation, where mass transfer should be accounted too.
Old   October 27, 2015, 08:56
I think there are similar problems also with the heatTrasfer term:
const volScalarField& Tf(*Tf_[pair]);
*eqns[phase1.name()] +=
dmdt21*(phase1.thermo().he(phase1.thermo().p(), Tf))
- fvm::Sp(dmdt21, he1)
+ dmdt21*(K2 - K1);
*eqns[phase2.name()] -=
dmdt12*(phase2.thermo().he(phase2.thermo().p(), Tf))
- fvm::Sp(dmdt12, he2)
+ dmdt12*(K1 - K2);
In the first equations it should be:
- dmdt21*(phase2.thermo().he(phase2.thermo().p(), Tf))
+ fvm::Sp(dmdt12, he1)
- dmdt21*K2
+ - dmdt12*K1;
Can someone suggest me what is the best way to communicate these things to the developers?
Thank you
Mattia
Old   October 28, 2015, 04:38
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
I think the bug tracker would be the best way to communicate with the developers.
http://www.openfoam.org/mantisbt/my_view_page.php
They may ask for a particular simple test case.
Regards,
Tom
tomf is offline   Reply With Quote
Old   May 16, 2017, 10:08
openfoammaofnepo is on a distinguished road
Dear demichie,
I am also checking these lines about how to implement the momentum transfer due to the mass transfer. So here dmdt21 is positive, dmdt12 is always negative. So if the mass is from phase 2 to phase 1, then the change of mass is assumed positive, if the mass is from phase 1 to phase 2, then the change of mass is assumed to be negative.
So for phase 1, the velocity for dmdt21 is U2, which is OK,
for phase 1 again, the velocity for dmdt12 is U1, which is OK.
For phase 2, the velocity for dmdt12 is U1, the velocity for dmdt21 is U2.
Originally Posted by demichie View Post
Hi all,
where
Mattia
openfoammaofnepo is offline   Reply With Quote
Old   May 17, 2017, 10:32
Dear Demichie,
I found the same problem as you mentioned:
PHP Code:
Still regarding the mass transfer terms in the equationsI have not found it in the alpha equationwhere mass transfer should be accounted too
Did you finally confirm this issue for the source terms of mass transfer in the alpha equation?
U1Eqn =
Old   May 28, 2017, 12:46
rdbisme's Avatar
Ruben Di Battista
rdbisme is on a distinguished road
Originally Posted by openfoammaofnepo View Post
Dear Demichie,
PHP Code:
[EDIT]
Here you can find an explanation for what concerns the mass source in the alpha equations.
https://bugs.openfoam.org/view.php?id=1881
rdbisme is offline   Reply With Quote
Old   March 7, 2018, 12:41
us7
Umer
us7 is on a distinguished road
i am looking for something that explains “bubbleColumnEvaporatingDissolving” tutorial. I am not sure about few things in it like (air.gas, air.water) I set in the “0” directory. When I see results on paraView>air.gas . Can anyone say few quick words about it. May be it will work for me.
1. air.gas, air.liquid shows mass fraction or volume fraction? or Is it showing mass fraction in each phase gas/liquid? It means mass fraction "Yair" is multiplied with "alpha.gas"?
2. How diffusivity Df is calculated in the solver? Or its just a constant?
3. How this solver calculate concentration gradient dY? Is it coming from Henry’s Law Ys=k.Yg.rhog/rhos then it is multiplied with rho.phase to get the concentration gradient dY for mass transfer term? mass transfer= K. Df. dY
Best Regards,
Umer
us7 is offline   Reply With Quote
