Inter-process discontinuity during running in parallel
Old   March 15, 2018, 19:57
Default Inter-process discontinuity during running in parallel
zhaopeng
zp_chem is on a distinguished road
I created a new class base openfoam ,and I used this class to calculate but the result show that the interface of process is discontinuous (as the picture shows). Maybe I should add some interprocess communication, and I want to know does openfoam has relevant casa.
zp
zp_chem is offline   Reply With Quote
Old   March 20, 2018, 11:54
Hrvoje Jasak
hjasak will become famous soon enough
Please do reconstructPar and try to visualise the reconstructed case. It is likely, this is just due to the way Paraview reads decomposed data, ie, unlike FOAM, it does not do proper interpolation across processor boundaries.
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   March 21, 2018, 05:09
zhaopeng
Dear Professor Jasak
Thank you so much for your reply,maybe I should explain my problem more clearly,as the picture shows, they are the date(fIB) of processor 0 , processor 1 , after do reconstructPar and serial calculation respectively in paraview .
figure 3 and 4 show that there is big difference between serial calculation and parallel calculation . And i found that my problem is part of my date(fIB) near the interface of process is calculated in another process . I want to access them and add them to the corresponding process. Any help would be much appreciated.
zhao
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 10 February 22, 2017 21:33
How to use parallel running to the most? 6863523 OpenFOAM Running, Solving & CFD 5 January 19, 2017 02:22
parallel error with cyclic BCs for pimpleDyMFoam and trouble in resuming running sunliming OpenFOAM Bugs 21 November 22, 2013 03:38
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 04:59
Problems running in parallel - missing controlDict Argen OpenFOAM Running, Solving & CFD 4 June 7, 2012 03:50
