Error happens when 'scheme' and 'SCheme' are added in fvm::div()
Like Tree2Likes
  • 2 Post By Cyp
Old   May 8, 2018, 11:15
Default Error happens when 'scheme' and 'CSheme' are added in fvm::div()
Pei Li
HectorLee is on a distinguished road
Hello, everyone,
I am trying to simulate transport phenomena in two-phase flow and find a piece of source code for solving the advection-diffusion equation with the interface. For divergence part, it is written as:
fvm::div(phi, C, scheme) - fvm::div(phiD, C, CScheme)
After compiling the code, I got "error: ‘CScheme’ was not declared in this scope" and "error: 'scheme’ was not declared in this scope."
Although I searched solution using google, no solution is found. Is there anyone knowing how to fix this error? Thanks a lot.
HectorLee is offline   Reply With Quote
Old   May 10, 2018, 21:45
Cyp
Cyprien
Cyp is on a distinguished road
The compilation error sounds pretty clear to me: the variables scheme and Cscheme you are using as arguments to construct your matrix from the function fvm::div() are not declared.
There are two ways for solving your problem:
1: you don't call the fonction with three arguments but only two (the third one is optional)
fvm::div(phi, C) - fvm::div(phiD, C)
You will have to specify the discretization scheme for div(phi,C) and div(phiD,C) in system/fvSchemes
2: you declare scheme and CScheme before calling your functions:
word scheme    "div(phi,C)";
word CScheme "div(phiD,C)";
hjasak and HectorLee like this.
Cyp is offline   Reply With Quote
Old   May 15, 2018, 00:46
Pei Li
Thank you very much for your help, Cyprien. Sorry for replying you late, because I was in travel these days. I will try both methods later.
how to understand high resolution scheme and high order scheme iilw1314 Main CFD Forum 7 April 12, 2022 12:29
can you tell me best gradient, pressure & momentum order selection in fluent sanjiiv FLUENT 6 February 14, 2020 06:07
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Godunov scheme Peter Main CFD Forum 6 November 27, 2009 10:51
extrapolation in MUSCL scheme Chandra Main CFD Forum 6 February 14, 2007 11:21
