Sourcecode for Namespace Foam
Old   August 16, 2018, 08:52
Default Sourcecode for Namespace Foam
Tony Zahtila
tzaht is on a distinguished road
I have recently been struggling to find where the source code with 'actual' mathematical expressions that are within OpenFOAM. In particular, I want to see the source code that will define the particle collisions in DPMFoam.
However, I would be satisfied at this instance even to see where the lagrangian operator is defined.
In short, I am struggling to get past top level classes and down to the actual maths.
I have a hunch that this is all defined in the namespace Foam. However, I cannot find where the source code is for the namespace Foam.
I also slightly suspect that I may be misunderstanding what the Foam namespace is and that it is distributed among very many files.
Any direction would be greatly appreciated,
Kind regards.
tzaht is offline   Reply With Quote
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 02:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
